05-25-2006, 09:58 PM   #1 (permalink)
yacobco5
no oil pressure
Hello,
I recent have come into a problem with my oil pressure on my 1990 fox mustang. It has a 331 built motor with a high volume oil pump(debured etc...) and an arp hardened shaft. Anywho it recently started reading below zero on the stock gauge inside the car at idle. If any gas is applied it goes back up to the normal zone. we pulled the dist to look at the shaft and dist itself. Both seemed to be fine. I spun the pump with a drill and the pressure remained constant and I could see oil flowing. I also recently got a new oil pressure sending unit as well. Any ideas?
yacobco5 is offline   Reply With Quote
05-25-2006, 10:12 PM   #2 (permalink)
mstngjoe
no oil pressure
I would first hook up a mech gauge and verify the readings you're getting on the factory gauge.
05-25-2006, 11:32 PM   #3 (permalink)
yacobco5
no oil pressure
Thanks for the reply. I will get a mechanical as soon as possible.
05-26-2006, 01:26 PM   #4 (permalink)
rcm600
no oil pressure
What mstngjoe said
rcm600 is offline   Reply With Quote
05-26-2006, 07:10 PM   #5 (permalink)
89521coupe
no oil pressure
Hi I hope iam wrong but if you have ran it real hard and it detonated hard you have cracked the block in the main webs and spit out a cam bearing.GOOD LUCK AND GOD BLESS B.C.
89521coupe is offline   Reply With Quote
05-26-2006, 08:06 PM   #6 (permalink)
mavman
no oil pressure
Is it making any noises?
Id do as mentioned. Get a mech. gauge and verify that the pressure is in fact zero. Hopefully, it's a wire or factory gauge problem...which is fairly common.
If it is in fact zero, and you can feel resistance on the pump when spinning it by hand...could be split block like mentioned, but I'd be more inclined to think that one of the front galley plugs came out. Same thing happened to me...numerous times. 302's have press-in plugs and with a HV pump sometimes they can come out. I now tap them all. No drilling required, just run a 1/4 NPT tap in there put a few threads in it, and screw a plug in.
05-27-2006, 07:09 PM   #7 (permalink)
yacobco5
no oil pressure
We got a mechanical gauge and verified that there is zero to no oil pressure while running. Where should I go from here?
05-27-2006, 07:39 PM   #8 (permalink)
mstngjoe
no oil pressure
Is this a fresh build? If not, how many miles on it?
Is that zero pressure at idle or all rpm?
05-27-2006, 09:55 PM   #9 (permalink)
yacobco5
no oil pressure
0 at idle and 20 psi at 3000-4000 rpm
05-27-2006, 10:05 PM   #10 (permalink)
mavman
no oil pressure
Id pull the cover off first and have a looksee
