coil resistance
I have a 1984 mustang 302 TFI CFI . automatic I have no spark so I went through the tests in Manual first test was coil it states that you should have 0.4-1.0 ohm on primary and between 8,500-11,000 on secondary my coil showed bad secondary test bough new one from NAPA and tested 2 different ones at the counter and I got 0.7 on primary and and with meter set at 200k it reads for secondary 0.79 and on 20K range it reads 7.95 ??is this any good?
