06-16-2006, 12:49 PM   #1 (permalink)
jimmife
convertible 84
How do you remove the filler rubber plug to check level on convertible motor resevoir. Tried some prying don't want to force it.Thanks
jimmife is offline   Reply With Quote
06-16-2006, 09:36 PM   #2 (permalink)
Ronbuell
convertible 84
Use a small screwdriver, and work it under the top cover, straighten up, then around and thru the hole, then push it thru at an angle, but only a small amount. When you get that, the try to pry it out. They usually will pop right out. Be careful and try not to cut the plug. I use a straight blade that is about 1/2 width of the hole.
06-17-2006, 11:36 AM   #3 (permalink)
jimmife
convertible 84
