Too much pressure in motor, NEED HELP??
are you sure the intake is mated up to the heads properly.
ive had that full throttle smoking problem before ,used to smoke like hell when i opened it up,turned out oil was being sucked up between the intake and heads causing it to burn oil and really smoke,when i took the intake off there was a heap of carbon buildup on the back of the inlet valves
<font size=-1>[ This Message was edited by: steharz on 6/26/06 11:27am ]</font>
