08-20-2006, 08:55 PM   #31 (permalink)
stangfanatic
Why is my car so slow??
i'm in the hunt for a set of motorcraft plugs....autolite plugs are good. anything from the regular ones to the platinums<U></U>
stangfanatic is offline   Reply With Quote
08-21-2006, 04:11 AM   #32 (permalink)
89Saleen
well i finally had the time and dug into the car a little and found a few problems. Someone somewhere along the lines had attempted to port the throttle body, mass air sensor, and intake manifold. The thottle body is garbage, it looks like a stop sign inside of it. the intake manifold is rough but i think it can be saved, and the mass air sensor.......isn't there supposed to be a honeycomb stuff in there? because its bare and you can tell where its been smoothed out, though its all a very rough finish, as if they did the 'port' but not the polish. the lower intake stayed on the car so i'm not sure of any damages if any were done to it or the heads. Though it doesn't look like they got ballsy enough to try and port the intake runners (thank god) also when i removed the upper intake plenum i found out that the rear bolts weren't tight. after pulling the first four bolts the plenum would rock back and forth easy and without loosening the rear bolts, would spin with little effort when i removed one of the two. Any estimations on how much power loss this porting (if you can call it that) and mass air unit might cause?
89Saleen is offline   Reply With Quote
08-21-2006, 06:23 AM   #33 (permalink)
dfree383
You know it Captian Platnium !! (Cledus) LOL Platniums are for Newer stuff with hotter combustion chambers and ignitions !!
On 2006-08-03 11:18, dfree383 wrote:
I would get everything fixed right before you go advancing the timing. Have the fuel pressure checked and replace the O2 sensors (they do need to be replaced every so often anyway) after you get the EGR Stuff Worked out and verify their are no other problems. Then bump the timing.
And ditch the platnium plugs and put some regular motorcrafts in.
1991 LX Mustang 347 C4 combo 11's with the AC on.
1984 Mustang GT 460, Powerglide "Still putting it together" hoping for 9's !!
1929 T-Altered "In the works" 8's are on the horizon
<font size=-1>[ This Message was edited by: dfree383 on 8/4/06 2:19am ]</font>
ya u better change those plugs or you will never here the end of it!! right dfree383 lol
dfree383 is online now   Reply With Quote
08-21-2006, 06:26 AM   #34 (permalink)
dfree383
Definate Problem with the vaccum Leaks and ditch the home ported parts, Improper work can really screw everything up !! It's a big enough pain in the Arse getting everything working right with most modified EFI systems, let alone a home hack job !!
08-21-2006, 01:19 PM   #35 (permalink)
89Saleen
heres a few quick pics of the home ported parts that some 'genius' of a previous owner did
<font size=-1>[ This Message was edited by: 89Saleen on 8/22/06 3:20am ]</font>
08-21-2006, 02:54 PM   #36 (permalink)
rcm600
Nice work, I think he missed a spot!
rcm600 is offline   Reply With Quote
08-21-2006, 03:07 PM   #37 (permalink)
dfree383
Ouch, They need to issue permits to operate grinders..............To keep the hack's from getting their hand on one !!!
08-21-2006, 07:20 PM   #38 (permalink)
stangfanatic
you might be right about the heads...but that mass air for sure is ruined. heck...trying to move more air and not fuel compensating...stupid. now youll need to be sure it even had matched injectors also. Nows when id look into a better performance intake and throttle body unit.
08-21-2006, 07:21 PM   #39 (permalink)
stangfanatic
Im not having any issues with the autolite double platinums....except thay burn really clean.
