08-02-2006, 10:06 PM   #1 (permalink)
danzig666
Higher compression
I was thinking 11:1 on a 331 stroker with a 100 shot for the track. AFR 185's, custom cam, and a 750 carb, long tubes.
What kind of numbers do you think this would make excluding the nitrous?
I want to be able to run 93 octane with out nirtous.
danzig666 is offline   Reply With Quote
08-11-2006, 11:27 PM   #2 (permalink)
badmts
Higher compression
low 13's to high 12's depending on weather and traction and altitude
badmts is offline   Reply With Quote
08-13-2006, 08:21 PM   #3 (permalink)
Magic
Higher compression
should be in the 12s on the motor with the setup like that....
Magic is offline   Reply With Quote
08-19-2006, 10:15 PM   #4 (permalink)
82GT
Higher compression
12's with motor and 11's with the 100 shot
08-20-2006, 07:47 AM   #5 (permalink)
fastpony2nv
Higher compression
My 80 coupe runs 11.90's with a similar set up less the nitrous. I run a 331 w/ 12.1, brodix heads, custom cam, 4.30 gears and a 5 speed on slicks.
fastpony2nv is offline   Reply With Quote
08-21-2006, 07:20 AM   #6 (permalink)
tachrev351w
Higher compression
Mid to high 11's is my guess.
tachrev351w is offline   Reply With Quote
