09-19-2006, 03:02 PM   #1 (permalink)
SweetStang
Hey MavMan
Could you tell me how to wire up the electric fan to a Bosch 75A Power Relay. You responded and said this is the way you wired yours up but with a toggle switch. Thanks for your help!!!!!!!!!!!!!!!!!!!!!!!!!!!If you have a schematic you can send it to SweetStang@bellsouth.net. Thanks
SweetStang is offline   Reply With Quote
09-19-2006, 06:41 PM   #2 (permalink)
mavman
Hey MavMan
Find a power source, whether it be powered with the key on or not..it's up to you (might want to find a key-on source so you don't forget to turn it off & kill the battery). That wire goes to your toggle switch. From the switch, run a wire to the relay's power on terminal. Then run a wire from the battery (or starter solenoid or wherever..) to one side of the relay, another wire from the relay to the fan, and finally a ground from the relay to...of course a GOOD ground.
The relay should come with a schematic showing which terminal does what. Fairly simple.
this should give you a couple ideas:
http://www.super7.dk/fan.html
