02-13-2007, 09:13 AM   #1 (permalink)
Otto
Rattling convertible top
The top on my '93 5.0 is rattling quite a bit. I've looked in my factory manual and it doesn't cover how to fix this. How would I go about tightening the top again? Thanks!
Otto is offline   Reply With Quote
02-13-2007, 12:05 PM   #2 (permalink)
spd691
My 91 vert was rattling also, sounded like someone banging on the top of the windshield. I found it to be where the pins go into the header. There are supposed to be little plastic funnels in th holes. I installed those and installed the plastic pieces that the hooks grab and my problem was gone. Took a while to figure it out though.
spd691 is offline   Reply With Quote
02-15-2007, 12:46 AM   #3 (permalink)
Otto
Sorry for the late reply and thanks. The rattling actually started in the front above the windshield. Now its at the rear passengers side, above my and and the front. I blame the bad LA roads and my stiff suspension. I will check out your solution and ill let you know how it went. Thanks!
