Re: 1989 mustang lx power door locks
Sure buddy!
Open the door panel and probe the controll to the locks for power with the Key ON.
With the key in the ON position you WILL have power to the door locks if the wiring is good. It is a fuseable link wire and not fused, so you need not look for a blown fuse.
If you have power, probe the other side of the switch for power when you activate the switch.
A simple test light will work for this.
If there is power to the other side if the switch and the locks do not actuate then you need to sheck for power at the LOCK side of the wiring.
If you have power there, you must replace the broken lock actuators.
How's that?
FE
