Re: Timing a 91 302
on a 91 5.0 motor they are on the passenger side thats bolted on by the two botton bolts of the timing cover,and the number 1 piston is on the passenger side to.. just get the piston at compresion top dead and point the rotor to the #1 spark plug post on the cap and then you should be in the money.. but you will need a timing pointer to advance it because those engines run about 12 dagree advance good luck
96 stang
5.0 - c4
