07-13-2007, 03:55 PM   #1 (permalink)
1badasslx
4cyl springs??
hello im building a 89 mustang that was a 4cyl. and i keep hearing about people running 4cyl springs in there v8 cars, why? dose the 4cyl springs lower car? give more bite? do you run them in the front or rear, or both?
thanx for the help fellas...
96 stang
5.0 - c4
1badasslx is offline   Reply With Quote
07-15-2007, 09:33 AM   #2 (permalink)
wildosvt01
Re: 4cyl springs??
a- yes it lowers the car a bit
b- on the strip it should
c- both
Im finishing up this swap right now and took it for a ride yesterday.
Wildo
1965 Galaxie Fastback-351C 2v/C4 with a 3.50 Trac-Loc
2007 Torch Red Shelby GT500
2004 Marauder/2004 Cobra
[b]Out of a job yet? Keep buying foreign!![/b]
07-16-2007, 02:43 PM   #3 (permalink)
1badasslx
Re: 4cyl springs??
i was told not to use them in the rear is this true?
96 stang
5.0 - c4
07-16-2007, 08:08 PM   #4 (permalink)
wildosvt01
Re: 4cyl springs??
I have about 2 miles on her now (Im waiting for the front end alignment on Wednesday for a longer trip) and I see no I'll effects from having the 4 banger springs in the back or front. From what I have heard they (rears) are better for weight transfer due to being softer. Honestly, It seems to ride pretty damn good!
Wildo
07-17-2007, 08:36 PM   #5 (permalink)
1badasslx
Re: 4cyl springs??
sweeeeeet.... keep me posted on it.. it will beawhile before i get to drive mine. still building rearend,motor,and other stuff.. but i think i will run them in the rear and front to.. thanx
96 stang
5.0 - c4
07-18-2007, 08:19 AM   #6 (permalink)
wildosvt01
Re: 4cyl springs??
The front end is being aligned as I type this. I also went to the local pick and pull and got a V8 brake booster. I left the master cylinder and lines on it to make life a little easier when it comes time to install. My master (currently in the car) seems shot, So I said screw the 4cylinder booster and I'm knocking out two birds with one stone. So if all goes my way today I will take her on a long run and see how she goes and report back as soon as I can.
Wildo
Wildo
07-18-2007, 08:34 AM   #7 (permalink)
gerzen
Re: 4cyl springs??
hey im thinking to install a rear 4 cyl springstoo, i have a v8 convertible, are the same springs in the 4 cylinder convertibles and 4 cyl coupe and hatch back? im asking because i know the V-8 (coupe and HB) and the v-8 convertible use diferent springs, so can i install any 4 cyl spring or i need to look at 4 cylinder convertible springs for my stang? also if i just install that 4 cyl springs in the rear im going to have the car to raise in the front?
gerzen is offline   Reply With Quote
07-18-2007, 02:43 PM   #8 (permalink)
1badasslx
Re: 4cyl springs??
not sure about the fitment of the springs between convert and coupe i would think they are the same.. but as far as the front you would prob have to lower if you dont use the springs in front aswell.. the 4cyl spring will lower car a little bit cause there softer than v8 springs...
(correct me if im wrong)
96 stang
5.0 - c4
07-18-2007, 05:55 PM   #9 (permalink)
wildosvt01
Re: 4cyl springs??
The fronts lowers her down a bit. But I do not see much of a change out back from when there was'nt an engine in it.
I have a bunch of interior pieces not buttoned up yet do to the dredded heater core and pass. side exterior door handle. So my car is doing that "Shake, Rattle and roll!"
Wildo
07-19-2007, 05:08 PM   #10 (permalink)
wildosvt01
Re: 4cyl springs??
Ok, I installed the V8 booster and the master cylinder. Both known to be good which they are.
Wheels are aligned (needed one tie rod end, GO FIGURE! Which led to my bill being ridiculously high) and took her for a couple of runs. It felt a bit squirrelly. Im feeling that it may have to do with the wheel/tire combo I currently have. So I will be getting some lug nuts to install the set of Pony's I have to see exactly if its the wheels/tires currently on the car.
I'll tell you what though, You hear every bump out back with full poly bushings!! LOL!
Wildo
89 4cyl lx to 302 v8 convert? 1badasslx Mustang Pages (1979-1995) 2 07-06-2007 09:29 AM
Converting a 4cyl. fox to 5.0 EFI. wildosvt01 Late Model EFI Techboard 10 04-08-2007 08:04 PM
4cyl to v-8 conversion 50brando Mustang Pages (1979-1995) 7 04-17-2006 06:11 PM
4CYL to 390 JLH All Ford Techboard 8 06-06-2005 08:50 AM
'88 Fox 4cyl / V8 Swap Cobra77 All Ford Techboard 11 01-19-2002 05:51 PM
