08-02-2007, 08:26 PM   #1 (permalink)
Ronbuell
Stock radio question
89 LX coup, radio didn't work when I got it but tape played. I thought bad radio. Nope, blown fuse in fuse panel which also supplies the dome light. Replaced the fuse, bonus, both now work, but, the radio LCD doesn't light up, so I've got no clock and no way to tell what station I'm on unless I listen for the call out from the station.
Is there a light inside the radio I can replace and get the display back up?
I tried pluggin in an aftermarket radio and it came on, but didn't play, so there something going on with the wiring.
08-02-2007, 08:56 PM   #2 (permalink)
CaptVirgilHilts
Re: Stock radio question
There is a TINY little bulb in there. It is a peanut style bulb but is really small and Ford doesn't sell it oddly enough. I found one the same size used as an ignition key courtesy light in a '91 Escort column. My suggestion is take the stereo out pull the top off and take the micro bulb out and into a good parts place that has a selection of bulbs.
You should still be able to see the LCD digits without the light albeit faintly. It may be your LCD is gone bye bye too.
Stu
1967 Mustang Coupe
Radio question wayne64 All Ford Techboard 1 03-25-2006 04:14 PM
67 Galaxie am/fm radio Question Chiefe9 Galaxie Pages 2 09-22-2005 08:09 PM
Stock Looking FM Radio? HankyJ All Ford Techboard 2 11-23-2003 11:20 PM
Stock 302 oil pan question voot61 All Ford Techboard 5 07-10-2003 09:59 PM
odd question.. any ham/cb/broadcast radio guys out there? jeremyl The Garage 6 03-24-2003 12:24 AM
