01-11-2008, 02:09 PM   #1 (permalink)
rmousir
Exclamation Head swap questions - please help
Hey All,
I picked up a set of GT-40Y heads from a buddy for a good price and they have less than 10K on them. I have never swapped heads before. I have a '95 motor that is running a carb now. What do I have to do to swap them? What do I have to get?
They are in good order and I figured I can just move my rockers on to them from my stock head. Put on some new gaskets and bolt them on. Is it that easy? What else do I have to do? Any and all help would be appreciated. Also what kind of power gains can I expect? Just running a stock '95 motor with 600 4bbl carb, dual plan intake, and 2.25 exhaust from long tube headers.
Thanks very much for any and all info that you can provide.
Richard.
Richard
1966 Mustang Coupe
\'95 roller 302, auto
warmed up just a little
check out my site: http://budgetrestomod.weebly.com/index.html
rmousir is offline   Reply With Quote
01-11-2008, 03:39 PM   #2 (permalink)
mustang42782
Re: Head swap questions - please help
I doubt you will notice much difference
01-11-2008, 07:26 PM   #3 (permalink)
rmousir
Are you serious?? No difference at all? There will be no difference? Really?
Richard
1966 Mustang Coupe
01-11-2008, 07:30 PM   #4 (permalink)
I believe there will be little noticeable diffrence. Not "none" just not a lot.
Do you know the physical diffrence in the heads I.E. Chamber size valve size Etc... As compared to yours?
FE
01-11-2008, 08:41 PM   #5 (permalink)
rmousir
right now I have stock 5.0 heads from a '95 motor. the GT40Ys are a little old but they breath much better than my stocks ones I am sure.. here are the specs on the heads:
GT40Y
Intake valve - 1.94
Exhaust valve - 1.54
Int.100 - 64
Int.200 - 114
Int.300 - 167
Int.400 - 199
Int.500 - 213
Int.600 - 217
I don't know what my stock heads are. I will take a look and see what I can find for specs on them. This is what I found but don't know that it is accurate yet.
The stock valve size is 1.78 intake and 1.45 exhaust. Combustion chambers are 61.5 cc's
Ford 302 E7TE Iron
Intake valve - 1.78
Exhaust valve - 1.45
Int.100 - 52
Int.200 - 95
Int.300 - 132
Int.400 - 143
Int.500 - 159
Int.600 - n/a
I also have a nice dual plan intake, not the greatest but nice. On the other side I have Headman long tube headers with dual 2.25 pipe out the back. Will also be adding cut outs and a cross over pipe this summer.
According to my reading these heads work well for both stock set ups and modified motors. I don't expect a 40 hp gain on these but I am sure that they are worth 20 to 30 for the stock motor and a lot more with a cam. One article I read said it was money well spent. Then another article said not to waste my money. Man.. I just wish I knew.
Richard
1966 Mustang Coupe
Some questions about Cleveland head swap and engine rebuilding. sharpshot71 All Ford Techboard 9 03-01-2006 02:32 PM
5.0 Head questions dbu8554 Late Model EFI Techboard 6 06-28-2005 05:01 PM
More E7 head questions? TheGmKiller331 All Ford Techboard 5 10-30-2004 11:50 PM
Head questions kleetuz All Ford Techboard 1 03-17-2002 03:47 PM
Head questions kleetuz All Ford Techboard 3 03-05-2002 09:59 PM
Probe Industries
