01-16-2008, 02:00 PM   #1 (permalink)
focusgm
Cool 84 Stang Conv. Shift Handle
Guys,
I want to replace the shifter seal that is located right under the P-R-N-OD-D-1 bezel on my 84 stang convertible and I don't know how to remove the auto shift handle. It currently has no seal and you can look past the shift mechanism all the way to the carpet underneath the console. Not too cool!
Do any of you have experience in how to remove this handle? The handle I am referring to is the one you grab to place the car into gear and has the release button on the drivers side of the handle.
Thanks alot,
Focusgm
focusgm is offline   Reply With Quote
01-16-2008, 07:35 PM   #2 (permalink)
79cobra
Cool Re: 84 Stang Conv. Shift Handle
there is a set screw on the handle of the shifter take it out push the button in and pull up on the handle and it should come off
79cobra is offline   Reply With Quote
01-16-2008, 08:08 PM   #3 (permalink)
CaptVirgilHilts
79 Cobra may be right but, I'm pretty sure Ford did away with the set screw by '84. If there is none then you just grab it firmly and pull up very hard and it will pop off.
Stu
1967 Mustang Coupe
01-16-2008, 09:11 PM   #4 (permalink)
focusgm
Guys,
I could not find a set screw anywhere on the handle so will give it a hard yank after the sun comes up in the morning.
Thanks alot for the help!!
Focusgm
b&m trick shift, hurst hot shift, type f, or dexron mercron? what do i use! greasemonkey85 C4 Transmissions 10 04-23-2008 01:11 AM
does anyone make a nice shift kit for my 66 Stang C-4 65289pony C4 Transmissions 2 05-22-2007 01:08 PM
Need a Hurst shifter handle for a \'66 \'Stang BAD! BobbyD All Ford Techboard 1 06-07-2004 09:27 AM
8.8 cougar rear into fox stang w/ t-bird TC rear disc conv. or 5 lug conv. with rear disc Foxbodystang All Ford Techboard 1 11-30-2003 09:36 PM
Shifter Handle \"play\" (column shift automatic) Dogface Galaxie Pages 0 04-08-2003 04:55 PM
