Re: motor swap tranny help?
Are you goin going to use a Manual or Automatic?
I swiched my 1991 from a 5 speed to C4 a few years back, You'll need a SB C4, Correct Balance and Sized Flex plate, Auto Starter, Correct Convertor for the C4 you use. Keep in mind their are several different C4's so whatch what parts you get and make sure of the balance of your motor (will be either 28oz or 50oz) depending on what year it is.
The drive shaft will be hit or miss, my t-5 drive shaft worked with the C4 I used, just need about a 3/8" spacer (can't rember the exact dimension) on the rear end yoke.
As Far as Shifter, I used a Hurst 1/4 Stick, They are about $160, but you can probably get a factory Ford 3 speed auto floor shifter to work if yu on a budget.
