02-27-2008, 11:17 PM   #1 (permalink)
amc032
hydraulic cam on efi 302
hi i was wondering if i could run an hydraulic cam on a fuel injected 302 im tryin to stay on a budget build
would it work if i changed the distributor gear?
would i have to run speed density or mass air?
any help is appreciated i know u guys wont let me down
amc032 is offline   Reply With Quote
03-12-2008, 10:42 PM   #2 (permalink)
anthonydalrymple
Re: hydraulic cam on efi 302
Whoah..... Could you be any more vague?
If and it's a big if that I understand what you are asking..... You do not want to retrofit a standard hydraulic cam into a roller cam motor. Can it be done? Yes.... Why not do it then? 1)Because it's old tech. and will not make the power you're looking for, 2)It'll take the difference in money to buy the different length pushrods. There may be more issues that i don't know of since I'd never revert back from roller cams. My advice: save up the money, wait patiently for a good used cam deal (since they do not wear anywhere near as fast as a non- roller), and or spend the money where you'll really see big improvements (aluminum heads) IMHO.....
anthonydalrymple is offline   Reply With Quote
03-17-2008, 01:55 PM   #3 (permalink)
87stang
I'm in total agrement here.
Just use a stock 5.0 HO roller cam...especially if you're using EFI.
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
04-09-2008, 11:50 PM   #4 (permalink)
amc032
Yeah thanks guys appreciate the help i decided that ill wait and buy a used cam with some aftermarket heads.
-adrian
04-17-2008, 07:24 PM   #5 (permalink)
migg400
if you need a stock 5.0 efi cam, i have a few of them if you need one.
[SIGPIC][/SIGPIC]
1967 mustang fastback 418W EFI 5.spd
1990 7-up convert. lx 347 stroker 5.spd
2004 mustang gt bone stock 5.spd
migg400 is offline   Reply With Quote
Hydraulic Clutch Neil74 Galaxie Pages 0 05-25-2005 10:28 AM
hydraulic lifters hurri10209 All Ford Techboard 1 10-12-2004 11:18 PM
Hydraulic lifter – no hydraulic action? jeffstar All Ford Techboard 7 10-06-2004 01:39 PM
Hydraulic Clutch Oliaar All Ford Techboard 6 01-07-2004 07:57 PM
Best Lifters- Solid, Hydraulic, or Hydraulic Roller lakecityg All Ford Techboard 11 07-03-2003 02:46 AM
