03-05-2008, 05:41 PM   #1 (permalink)
galaxastang
5.0 cam choices
Need help choosing a cam. I have a 89 5.0 with GT40P heads. What's the biggest cam I can use with out worring about changing valve springs and p to v clearances? Any suggestions on a small budget like everyone else. THANX
The crows be pickin at your flesh if you ain't got control of the situation!
galaxastang is offline   Reply With Quote
03-05-2008, 05:47 PM   #2 (permalink)
dfree383
Re: 5.0 cam choices
Stock HO Roller or maybe a B303 or E303.....
I would still advise spending the $60-70 on a set of springs......
03-06-2008, 12:51 PM   #3 (permalink)
87stang
Re: 5.0 cam choices
I would just use the stock cam and 1.6:1 rollers.
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
03-22-2008, 05:31 PM   #4 (permalink)
galaxie
Re: 5.0 cam choices
On that motor you are very limited with the stock GT40 springs. I would upgrade to some Trick flow spings and even a trick flow cam. I currently run Trick Flow Twisted Wedge heads with a Steeda #18 cam in my 93 coupe. My 87 has stock 87 heads with a very mild crane EFI cam.
59,60,64,66,68 Full size fords
87,93 5.0 Mustangs
05 Lincoln LS8
WTB: 1960 Ford Wagon
Pittsburgh PA
galaxie is offline   Reply With Quote
Ignition choices pkmach1 All Ford Techboard 2 10-20-2006 11:09 PM
what are the choices? MODIFYD Late Model EFI Techboard 3 02-17-2004 03:24 PM
Spark Plug CHOICES? What heat range? any 18mm choices? 67fastback All Ford Techboard 6 01-17-2004 04:51 AM
too many choices. andwrong The Garage 0 12-29-2003 04:47 PM
cam choices? a little help! hamiltt All Ford Techboard 6 08-24-2002 02:18 AM
Powerhouse products
