03-31-2008, 01:16 PM   #11 (permalink)
87stang
Re: 5.0 302 V8 New Crate Motor Install
CHP 347 (short rod: 5.315", uses taller [more stable] 331 piston)
Flat-top pistons
Trick Flow Twisted Wedge heads (port matched to intake)
Holley SysteMax II intake
FTI custom cam
1.6:1 TFS roller rockers
AccuFab 70mm TB
75mm Pro-M MAS
24# fuel injectors (stock fuel rails)
FRPP 190 lph fuel pump
full MSD ignition system
1-5/8" shorties, and 2-1/2" exhaust w/ CATs
325 rwHP and 375 rwTQ through a T-5 and 3.55 gears
It's not the most powerful version of a 347, but it does pass emissions. This combo idles well, effiiciently pulls to 6k and will hit the 6250 rev limiter very easily. The torque curve is excellent too. If I were to do it again, the only thing I might change is the heads to AFR 185's.
Not having to fuss with emissions, a more aggressive cam and head combo will do a lot for the power numbers.
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
03-31-2008, 01:36 PM   #12 (permalink)
Mikes66
325 RWHP is a great number. Probably some room to get more with a little change here or there.... your red line seems a little low, but maybe a limit of the EFI system.
You will not be able to bolt on a blower. Your compression ratio will be too high with the flat top pistons. Your probably bewteen 10.0 to 11.5 right now.
[SIGPIC][/SIGPIC]
04-01-2008, 07:39 AM   #13 (permalink)
87stang
I think you've got me confused with someone else. I'm not interested in a blower on this combo...just sharing what I did with the original poster.
If I were to go power adder, my preference would be a single turbo anyway...and the whole shortblock would require some beefing up.
Dave
Cobra brakes
CHP 347
514 Crate Motor fast63sbf Galaxie Pages 4 12-03-2005 09:08 AM
crate motor or do it yourself ??? NoLongerHere2 All Ford Techboard 19 03-14-2004 10:51 PM
Crate Motor duckmann Fairlane Pages 0 11-22-2003 05:34 PM
514 crate motor BING1 All Ford Techboard 1 08-12-2003 08:17 AM
Crate Motor oil-pan RacinGator All Ford Techboard 0 05-04-2003 08:32 PM
