03-26-2008, 12:58 PM   #1 (permalink)
davewilly
83 5.0 Mustang Starter Problem
My son is trying to get his Mustang started, It has sat for about 13 months.
He put in a new, Batt & replaced the Solinoid and the starter. it has power and kicks out the bendix gear but wont turn over the motor. Any of you ran into this problem yet?
Thanks, Dave
davewilly is offline   Reply With Quote
03-26-2008, 02:14 PM   #2 (permalink)
Beoweolf
Re: 83 5.0 Mustang Starter Problem
Thanks, Dave
Just brainstormin'.... have you checked to see if the engine might have "frozen"? Put it in gear, if its a stick, see if you can push it, that will move the engine (if the clutch is still good).
Alternative: get a good size 3 foot long breaker over bar and proper size socket - this time with the transmission in neutral - see if you can turn the crank, only need to move it once around. After that see if it cranks.
Is it possible that the starter is bad or the flywheel ring gear is toothless? If it energizes the starter It probably isn't the solenoid
03-26-2008, 02:24 PM   #3 (permalink)
dfree383
Grounds all Clean and Good? May not be getting enough power to the starter.
New Battery doesn't mean its good need to check the voltage on it too.
Also check the resistance in the cables, they go bad sometimes too.
03-27-2008, 06:54 AM   #4 (permalink)
davewilly
I told him to try turning the motor over by hand....but I not sure he has tools to do it. ( he Lives with his mom and they dont have much in the way of tools) I also told him to try rocking the car while in gear to see if the motor turns over. So maybe he will get to try it today before he goes into work.
I also told him to check the grounds make sure they are clean and making a good connection. I will ask him if he put new cables on. I dont remember if he said he changed them yet or not.
Thanks for the info.
Dave
03-27-2008, 06:32 PM   #5 (permalink)
Pegleg302
Have or help him pull the spark plugs, spray some CRC,WD40, or PB BLASTER in the cylinders, let it sit for a few hours, then crank with no plugs (disconnect coil to be safe) I have seen many a broken piston ring from rust in cylinders.
Pegleg302 is offline   Reply With Quote
Solved my starter problem unfairlane All Ford Techboard 7 04-25-2007 01:42 PM
Help a Friend ... starter problem with 351C C4 combo ... his email ... help appreciated MonsterMach All Ford Techboard 3 05-28-2003 08:36 AM
starter problem - update - still not fixed!!!! musthave302 All Ford Techboard 6 08-28-2002 06:52 PM
Starter problem after swap Robbi All Ford Techboard 4 02-26-2002 09:32 PM
Starter problem zICRONIx All Ford Techboard 2 02-24-2002 05:39 PM
