03-27-2008, 02:40 AM   #1 (permalink)
Aggie
Stock injectors
What is the Max HP for stock 19 pound injectors, i have done some mods
on my motor and getting ready to install my AFR 165. I already installed
a 255 fuel pump and didnt know if i need 24s, iam still running speed density
and dont know if the computer will be able to read the 24s. Thanks, Aggie.
Aggie is offline   Reply With Quote
03-27-2008, 05:23 PM   #2 (permalink)
Beoweolf
Re: Stock injectors
It won't. Speed density works on pre-built tables, there is a little bit of tolerance in the system - mainly to accomodated wear as the engines get older and to compensate for variances in parts that is unavoidable in any mass production system. Changeing from #19 to #24 injectors without burning a new program is way past tolerance. Your choices are to have someone knowlegeable program an an overide chip or burn a new program to accomdate the new injectors. Problem is; it can get costly if you make many more changes.
What you can do, is fiddle with the fuel pressure to make the #19 work a little harder. It ain't a perfect solution but many guys have made it work. #19 are good up to about 250 - 270 hp ... if you tweecer them you might be able to get more, but it gets dangerous - in a big hurry.
Beoweolf is online now   Reply With Quote
Injectors for 427 DominickSch All Ford Techboard 0 01-24-2008 06:16 PM
30# injectors DominickSch The Garage 8 04-24-2007 08:51 AM
can i use 19# injectors?? saleenstang88 Mustang Pages (1979-1995) 1 08-28-2005 07:52 PM
19# injectors... 91gt All Ford Techboard 1 04-27-2004 01:37 PM
87 5.0 INJECTORS DEANO All Ford Techboard 1 03-18-2002 09:45 PM
