05-15-2008, 08:27 PM   #11 (permalink)
notched306
Re: 5 lug front conversion
Originally Posted by MCCUTCHEON4 View Post
Aluminum Vs Cast Iron? Did some of the 94 & newer have aluminum calipers?
One thing I am curious about is the width on the 94 up spindles and 11" brakes, I do not want to increase the track at all, do you guys know if using that set will make the wheels stick out?
using the 94-95 stuff will track the same width as the fox bodys.when you go 96 and newer then it tracks 8mm wider than the foxes.i did that on my 92 coupe and works just fine.they didnt go with the aluminum calibers till 99 when ford had a contract with PBR.all the rotors are the same size 94-04.now if your going to do rear disks then you need to get the brake booster and master cylinder from a 94-95 stang,v8 or v6 it doest matter.the fox master cylinder is a 2 port and the sn cars are a 3 port,so you can either get a pro portioning valve(not sure how to spell it) or convert the fox to a 3 port by taking the nut out of the p-valve that faces the firewall and get a fitting to fit it and make a new line.i also did that and works fine.you only need to do the conversion if your doing the rear disks and want them to work properly.you dont have to do it but your pedal will be alittle stiff but not bad.
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
05-29-2008, 09:10 PM   #12 (permalink)
jgagnon84
currently doing the conversion myself. if you use the 94-95 spindles, you will retain the stock fox body track width. I suggest you go to Sn95 Brake upgrades this is a great website that will explain everything. click on 79-93 5 lug to see conversion options.
jgagnon84 is offline   Reply With Quote
06-01-2008, 07:42 PM   #13 (permalink)
notched306
correct
Front end conversion Iethiopian Falcon Pages 10 11-02-2004 03:50 PM
Front Coilover Conversion 8BBL427 Fairlane Pages 14 12-06-2003 05:59 PM
front disc conversion Bogwan All Ford Techboard 5 02-09-2003 10:27 PM
front disc conversion Bogwan Falcon Pages 5 02-09-2003 08:22 PM
5 lug front rotor conversion...need help BBCFORD All Ford Techboard 16 01-13-2003 07:28 PM
