04-26-2008, 11:43 AM   #1 (permalink)
jonnys
94 cobra rear calipers
Hi guys just quick question, ive put set of these calipers on my 65 mustang and just need to know when you first use them do you need to set up hand brake like the vw golf calipers where you un wind piston just untill its a 1mm from touching pads before you pump pistons out hydraulically or can you just pump them out straight away.
Thanks in advance jonny.
jonnys is offline   Reply With Quote
04-29-2008, 08:24 PM   #2 (permalink)
notched306
Re: 94 cobra rear calipers
just turn the piston in which requires a special tool and slap them on.when you press the brake it will adjust out.to keep them adjusted you will need the e-brake cables cause everytime you pull teh e-brake it will re-adjust them if they need to be
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
04-30-2008, 10:13 AM   #3 (permalink)
jonnys
ok brilliant i shall do that,
thank you jon.
03 cobra rear rebuild 03svt Mustang Pages (1996-2004) 1 08-03-2007 09:09 AM
rear track width of Cobra GeoFordMan Mustang Pages (1996-2004) 0 04-15-2006 10:48 AM
Rear Main Seal 97 4v cobra motor 19mach69 Late Model EFI Techboard 2 06-28-2005 12:54 AM
rear brake calipers,9\" diff pmoylan All Ford Techboard 1 10-13-2004 01:11 AM
Explorer rear brake calipers mavman All Ford Techboard 7 10-14-2003 09:39 PM
