04-27-2008, 07:11 AM   #1 (permalink)
PaceFever79
Maximum Torque load for 4 bolt wheel studs?
Has anyone done real calculations on how much RW torque a hardened 4 stud axle / rim connection can take before snapping the lug studs? Will the 8.8 axle / splines usually fail before the wheel studs?
PaceFever79 is offline   Reply With Quote
04-27-2008, 09:08 AM   #2 (permalink)
Beoweolf
Re: Maximum Torque load for 4 bolt wheel studs?
Yup. The reason for 4 studs being better than 5 - personal opinion...if 1 is loose or missing, its not as big an issue. If they are all torqued correctly they should hold mostly the same. Now if you have a big offset rim, there will be more leverage agaisnt and thus stress on the studs...thats when it starts to be a problem.
Main Studs & Head Bolt? jetnoise All Ford Techboard 3 08-04-2007 12:52 PM
Main Studs & Head Bolt? jetnoise All Ford Techboard 0 08-03-2007 07:41 PM
ARP Main Studs/Torque 351bolt All Ford Techboard 3 08-25-2006 01:11 PM
Rocker studs for bolt down heads (78-later) capri331 All Ford Techboard 3 10-16-2004 08:28 PM
broken wheel studs zICRONIx All Ford Techboard 4 07-11-2002 02:30 PM
