04-27-2008, 01:41 PM   #1 (permalink)
94_ranger
Gt40 heads
Will GT40 heads work with a carbureted 302. Just wondering because all of the engines with GT40 heads are injected
94_ranger is offline   Reply With Quote
04-27-2008, 05:33 PM   #2 (permalink)
Mazlem
Re: Gt40 heads
The iron ones are bolt-on. GT40P's require special headers. The alum GT40-X's I *think* come in different combustion chamber sizes so you'd just need to be sure they won't up your compression too much, unless you want to run premium fuel anyway.
Mazlem is offline   Reply With Quote
04-27-2008, 08:09 PM   #3 (permalink)
notched306
Re: Gt40 heads
you are correct
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
04-28-2008, 09:51 AM   #4 (permalink)
87stang
Re: Gt40 heads
Also, consider piston-to-valve clearances if simply doing a swap to the big valved options.
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
04-28-2008, 10:38 AM   #5 (permalink)
dfree383
Re: Gt40 heads
Yes they will swap fine.
If you have the GT40-p ones you'll need to verify spark plug clearance with your headers, Special headers are not required in every case.
04-29-2008, 08:17 PM   #6 (permalink)
notched306
Re: Gt40 heads
another thing about the p heads is that you need to run a 98 explore spark plug.
GT40 heads 94_ranger Mustang Pages (1996-2004) 1 04-27-2008 01:17 PM
gt40 heads Carter06 Late Model EFI Techboard 15 10-14-2006 10:47 AM
How to ID GT40 heads? InfectedMushroom All Ford Techboard 5 05-04-2006 08:15 PM
\'94 GT40 Heads on \'68 302 greggieatthebat All Ford Techboard 15 03-01-2006 09:15 AM
GT40 Heads On A 289? Frodo All Ford Techboard 6 03-23-2004 02:23 PM
