04-29-2008, 12:29 PM   #1 (permalink)
Glara11
351C donor into Fox body coupe
so i went to pik and pull the other day just look around. and stumbled across this perfect 351 Clevland and i had to have it ...100$ and that thing was in my garage.
my intention is putting it in my lil 1993 v4 coupe. how simple is it? im keeping it carbed so im assuming its just drop in and go? im really looking for a clean and uncluttered look in my engine bay. ive gone ahead and bought a pair of hedman headers. also planning to use a 5.0 5 speed, and keep the rear end.
WHAT ELSE AM I MISSING??
What recommended parts to buy would you suggest?
thanks guys
Glara11 is offline   Reply With Quote
05-10-2008, 03:16 PM   #2 (permalink)
ibrm155
Re: 351C donor into Fox body coupe
[quote=Glara11;1409715]so i went to pik and pull the other day just look around. and stumbled across this perfect 351 Clevland and i had to have it ...100$ and that thing was in my garage.
the first thing u need to by a new k-member, you also need a 8.8 rear end because the 351c well rip the 7.5 rear into pieces, the stock 5.0 trans will blow also because of the engine's torque if u buy a built t5 trans it well hold up but to fit the t5 you'll need to buy a bell houseing to fit the 351,you will also need a need oil pan to fit the engine because of the fox-body k-member, you also need to change the fuel lines and remove the old fuel pump and buy a new mechanical fuel pump so the engine will get the fuel it needs to run u also need to buy a bigger hood because the 351 seats too high for the stock hood... their might be some other things you'll need to buy......
sorry for telling u the bad news but thats what you'll need to get........
ibrm155 is offline   Reply With Quote
05-10-2008, 10:30 PM   #3 (permalink)
steharz
5.0 bell will bolt right up to the 351c,any sbf trans will
81 aussie ltd-351w,rpm heads,performer rpm airgap intake,10.3 com,angus 1.6 rollers ,1 5/8 long tubes,750 edelbrock,comp xe274h,c4
82 GT mustang 302w-4 speed
55 two door ranchwagon
69 xw falcon wagon
steharz is online now   Reply With Quote
05-11-2008, 04:21 PM   #4 (permalink)
hoofkicker
Oil pan out of 1979 F-150 with 351 modified and pick up tube well work.A small hood scoop off Mustang well solve hood clearance problems.Your stock k member well work, but you have to get motor mounts.Don;t forget to get an electronic distributor anything out of 460 or 351 mod well work.
hoofkicker is offline   Reply With Quote
05-12-2008, 12:39 PM   #5 (permalink)
ibrm155
the 351 block is one inch taller
05-27-2008, 06:36 PM   #6 (permalink)
joshh
the k member is the same between the 4cyl and the 5.0 and depending on which intake u use it may fit under stock hood also a t5 will fit but may not hold up to the power same for the rear axle
67 mustang convertable
302 efi aod
67 coupe broke:(
30 model a truck future project
80 mustang coupe 4.6 4v project
joshh is offline   Reply With Quote
06-12-2008, 07:08 PM   #7 (permalink)
fordracer08
The 4 cyl. K-member and the 5.0 k-member are the same. Use the 5.0 motor mounts and space them about 1/2" to 5/8". The cleveland engine will not clear the hood. You will need to cut a hole in the hood and install a scoop. You can modify the 351M or 400 4x4 truck oil pan or buy one from Canton or Moroso. I have modified these pans and used the canton pick-up tube but this involves fabricating a new rear sump to use this pick-up. The bellhousing patterns for the 351C and the 5.0 are the same.Hope this helps.
fordracer08 is offline   Reply With Quote
64 Fairlane Sport Coupe Body Probolt64 Vehicles for Sale 0 12-29-2007 03:37 PM
351C-4V and C6 in a 67 Coupe Sam98961 Mustang Pages (1965-1973) 5 11-28-2005 10:06 AM
67 sports coupe body $100 type3kg Falcon Pages 0 05-05-2003 09:36 PM
Whats a 41 Willys Americar Coupe body worth? striebs All Ford Techboard 4 01-21-2003 08:30 PM
Fox body vs older coupe ????? dogman All Ford Techboard 4 07-29-2002 11:41 PM
Probe Industries
