05-18-2008, 02:32 PM   #1 (permalink)
82GT
question about 02 sensors
I accidently ripped the wires out from one of my 02 sensors while I was under the car of my '88GT. Will that do anything considering that they are probably the original ones and no good to begin with?
Will that cause the computer to go into another mode?
1982 GT
351w(.060), ported & polished heads with 1.94/1.60 valves, 10.3 comp, stealth intake, 274XE cam, Holley 750 dp, Mallory dist., shorty headers, flowmasters, 4:10 gear, c-4 with 3700 stall converter, subframes, electric fan
05-19-2008, 11:55 AM   #2 (permalink)
vristang
Re: question about 02 sensors
Yes, it will cause the ecu to stay in OL...
Replace the sensors.
1990 Mustang GT
Tweecer RT / X3Z
410w / Canfield 195's / CI-cam
My Site...
http://www.freewebs.com/vristang/
vristang is offline   Reply With Quote
05-19-2008, 02:51 PM   #3 (permalink)
82GT
Ok..next question: What's the best way to remove the o2 sensors that are rusted solid to the exhaust pipe? How does a garage do it?
1982 GT
05-20-2008, 03:58 PM   #4 (permalink)
flocko
Heat up the O2 bung nut with a torch until it is almost glowing orange. Then quickly put on your O2 socket and it should turn no prob. BECAREFUL with open flame under car. The longer way is to soak the bung every couple hours wit WD40 for about a day then let sit over night. May do the trick but be careful if you have to follow with tourch as WD40 highly flamable!!
flocko is offline   Reply With Quote
05-20-2008, 08:48 PM   #5 (permalink)
notched306
i agree.i just did that the other day on a car.
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
oxy sensors for headers hotroady Truck Forum 0 04-05-2006 02:15 AM
O2 Sensors AXE All Ford Techboard 5 01-06-2005 10:16 PM
O2 sensors??? torqueman0 All Ford Techboard 5 11-08-2004 01:47 PM
4.6L and 5.0L MAF Sensors CWToyota Late Model EFI Techboard 2 06-02-2003 04:25 PM
O2 sensors oils65mustang All Ford Techboard 2 04-26-2002 11:37 PM
Hays Clutches
