05-23-2008, 07:51 PM   #1 (permalink)
Ronbuell
Need electrical help, I think
Car is '91GT Vert. I wasn't driving it much over the winter, so I was just taking it out once a week or so. I hadn't noticed, but the battery had corroded up both posts. It had been starting, running, showing charge etc. Then one day I got ready to go, and it wouldn't start.
Checklist so far:
Checked fuel pressure, my gauge shows 38-40 measured when cranking, but fuel pump never shuts off like normal when ignition turned to run position. I usually turn the switch on, listen for the pump to come on and then shut off after pressure has built up, before I turn it on over to the start position. Has spark at plugs, I removed #1 wire and hooked up another plug, grounded it, and hit the starter and it sparked. Replaced relay under the driver's seat, no effect. Checked and replaced the starter switch in the steering column, the one that bolts to the steering column and the pin fits into to make the switch move back and forth. I'd replaced it when I first got the car, and the replacement was working its way loose anyway, so I caught it before it really failed. I'm wondering if the corrosion ate up the wires to the computer or is it really not getting up to pressure, and that's why the pump is not shutting off? Am I missing a pressure relay or sensor or something? I'm working on this thing now so Help appreciated from all the gurus!!
05-24-2008, 03:01 PM   #2 (permalink)
notched306
Re: Need electrical help, I think
maybe the hose on the fuel pump got very weak and got a hole in it.that will not have enough preasure to start the car
turbo notch,fully built 306 by yours trully,running on E85
notched306 is offline   Reply With Quote
05-25-2008, 01:50 PM   #3 (permalink)
Ronbuell
306, I'm not sure I understand your reply. If I had a hole in the fuel line, wouldn't I have a puddle of gas on the floor back there? I'm not getting any fumes or anything like that from a fuel leak, I don't think there is a leak like that. When the pump was running, I did push on the Shrader valve at the lines to the injectors, and I got fuel coming out there.
I'm thinking my next look is at the Salt and Pepper shaker connectors and the injectors. If the injectors aren't pulsing, that would keep it from running, and that would indicate harness, or computer, or something along those lines.
05-25-2008, 08:32 PM   #4 (permalink)
Ronbuell
Re: Need electrical help, Injectors not firing
Just for kicks, I checked some connectors in the engine bay. Then I sprayed some carb cleaner into the intake, hit the starter, and the motor fired up, but quit as soon as that fuel ran out. So the injectors are not getting their signal to fire.
What do I need to be looking for to get them back firing??
05-26-2008, 07:37 PM   #5 (permalink)
Ronbuell
Replaced computer, car running now.
electrical help Tracer64 All Ford Techboard 3 09-06-2006 01:34 PM
electrical lilrebel70737 Galaxie Pages 4 03-31-2006 05:13 AM
Need electrical help 89conv All Ford Techboard 3 05-22-2004 02:51 PM
Electrical experts wanted: electrical problem, please help =( !!! XolieX All Ford Techboard 21 01-05-2004 11:15 PM
What else can it be? (electrical) kewolfe All Ford Techboard 7 01-02-2004 10:38 PM
