05-26-2008, 08:15 PM   #1 (permalink)
jasper351
Big Block Ford in a SN95??
Hi, I was wondering if anybody here has put a big block ford into a SN94 (1994-1995) mustang. If so what modifications were required to make the engine fit. I know a cowl hood and motor plates would be required. Thanks.
jasper351 is offline   Reply With Quote
05-26-2008, 08:50 PM   #2 (permalink)
MY TWO STANGS
Re: Big Block Ford in a SN95??
You can do it with out a motor plate ford sells a pair of engine mounts and canton sells a OIl pan that will make the swap a snap . Two things that you will need are a bigger rad and headers there was a swap kit avalable but I don't remember who supplyed it . One of the guys at our local track installed a 496 inch big block into his 93 fox, now that car runs mid 10.s
05-27-2008, 06:48 PM   #3 (permalink)
jasper351
I knew you can put a big block in a fox body, but was wondering if it was any different putting it in a SN95 body style. Are the fox and SN95 platforms that similar?
05-27-2008, 08:50 PM   #4 (permalink)
MY TWO STANGS
The 94 -95 are the same other than the 94-95 engine is moved ahead 5/8 of an inch .To install the 460 you may want to move the engine back . You would have to remanufacture a cross member to run a C-6 or find a 351 M C4 Bell and tranny that will that will bolt right in .
SN95 into fox mikes82GT All Ford Techboard 11 06-20-2006 06:53 PM
FOX or SN95? toxicpelican Late Model EFI Techboard 6 09-09-2003 06:19 PM
When Did Ford change the balance on small block Ford engines? RonMeyer All Ford Techboard 1 03-09-2003 04:16 PM
Block prep for "557 BIG BLOCK FORD" Milodon 4 bolt caps or 2 bolt with main girdle? DynoTom All Ford Techboard 8 08-05-2002 02:23 PM
seriously considering a sn95 5.0 ElJefe Late Model EFI Techboard 7 07-26-2002 05:43 PM
