06-05-2008, 06:41 AM   #1 (permalink)
86GT306
Mass Air Conversion
Has anyone converter to mass air and hear of jumping clutch switch wires to prevent idle hunt or stalling? i'm told by a dyno shop that this needs to be done but unsure of correct wires or colors, any advice is appreciated, thanks
86GT306 is offline   Reply With Quote
06-05-2008, 07:32 AM   #2 (permalink)
Joel50
Re: Mass Air Conversion
A MAF conversion does not require you force a permanent "in-neutral" reading in the ECM. A problem in the Clutch Engage Switch (CES) and Neutral Gear Switch (NGS) can be verified by running a KOEO self test (transmission in neutral) and making sure failure code 67 is not present. A problem with the NDS signal (showing system is "in-gear" all the time) does cause an idle control symptom as shown in the vid here, but it's not required as part of the MAF conversion.
Joel50 is offline   Reply With Quote
mass-air conversion ndmus88gteng Mustang Pages (1979-1995) 5 09-26-2007 06:59 PM
Need help on mass air conversion Blownhorse Truck Forum 2 04-18-2007 02:09 PM
5.8L mass air conversion questions rgreenbank Truck Forum 0 03-13-2006 04:20 PM
Mass Air conversion problems!! fordman1987 Mustang Pages (1979-1995) 2 09-28-2005 08:07 PM
mass air conversion question??? saleenstang88 Late Model EFI Techboard 2 08-16-2005 07:03 PM
