06-13-2008, 06:47 PM   #1 (permalink)
flocko
Unhappy E7TE spring problem
I am having one heck of a time getting the keepers to release on my heads. Heads are out of the car. Using a " finger clamp" with the top compressor spinner but as much as I compress spring , keepers will NOT release????
flocko is offline   Reply With Quote
06-14-2008, 06:49 AM   #2 (permalink)
Joel50
Re: E7TE spring problem
A hammer is your friend...... tap on the retainers before compressing springs...... and some times you also need to tap them while compressed..... careful though.
Joel50 is offline   Reply With Quote
06-14-2008, 07:25 PM   #3 (permalink)
flocko
Question Re: E7TE spring problem
Yep, Compressed springs today and gave a light tap with the right size socket over the inner retainer and keepers pop right out. Exhast valves don`t have that problem as bad. Compress spring and then tap top of spring and keepers pop right out. Both valve trains took about an hour . Question: I started with the thermactor bumps so I could get use to the grinder, but when I grind them flush with the contour of the roof the thermactor holes become larger or elongated , if you will. Will this hurt anything????
E7TE-T vs E7TE-PA biglaw22 All Ford Techboard 0 10-27-2007 10:02 AM
valves for a 5.0 e7te wendellruth Mustang Pages (1979-1995) 2 01-28-2007 09:44 PM
Coil spring/leaf spring advice 63Sean Galaxie Pages 4 02-09-2005 04:58 AM
AFR205 Valve Spring Selection - Which Spring Pressure? alanmacdougall All Ford Techboard 6 01-04-2005 07:53 PM
LEAF SPRING PROBLEM BLACK65FORDFALCON All Ford Techboard 12 07-26-2002 02:11 AM
Powerhouse products
