03-28-2009, 10:31 AM   #11 (permalink)
blownsn95cobra
Re: weight reduction?
hahaha yeah maximum motorsports is most def maximum momeyi mean i can afford it butt i wanna built a motor
blownsn95cobra is offline   Reply With Quote
03-30-2009, 10:29 AM   #12 (permalink)
bassman97
That was in reference to carbon fiber.
However, don't put a price tag on quality. The QA1 may be a nice piece but considering the lack of meat in it and no cross brace (Ford must have a reason to use one as stock), that makes me nervous. For street use, I'd go MM.
04-11-2009, 05:40 PM   #13 (permalink)
1 Bad 88 GT
Originally Posted by Bullitt331 View Post
Last time I looked the stock 94/95 Mustangs had glass hoods, and rear decklid. I lot of $ to pick up maybe 5-8 lbs at best.
On my car I got rid of the A/C and the P/S and front sway bar. With a full QA1 front suspension the car still handles extremely well, even without the front sway bar.
You need to check again. All OEM body panels were steel.
07 Victory Vegas Jackpot
93 F150 4.9, AOD(winter beater)
89 5spd Coupe, 351C EFI Spyder, AGS 4 suspension
80 LX 11:1 carb'd 351C w/GForce T5, 17x9 95 R's(daily driver).
04-12-2009, 08:37 AM   #14 (permalink)
Bullitt331
As of 1994 ALL Mustangs have had fiberglass hoods and rear decklids. Ford did that to help shed a few pounds off of the now heavier cars. Go check, (I just did on 3 different cars) the hoods and rear decks are fiberglass.
Bullitt331 is offline   Reply With Quote
04-13-2009, 07:03 AM   #15 (permalink)
bassman97
On my 03, I'm pretty damn sure it's steel, however, the reinforcements on the underside are fiberglass.
04-13-2009, 01:36 PM   #16 (permalink)
Bullitt331
Talking Re: weight reduction?
Well if you can get a magnet to stick to it let me know, because I want the worlds first fiberglass magnet! We have in stock a 03' Cobra and a 94' Cobra, plus an employee has a 04' Cobra, another employee has a 94' GT and another has a 00' GT. They all have the stock fiberglass hoods on them. The re-reinforcement may be steel (hood catch, hinge area) but the rest of the hood is fiberglass. And so is the rear deck lid! At least now you do have to worry about buying a glass' hood!
04-13-2009, 03:19 PM   #17 (permalink)
bassman97
Banging on both sounded like steel to me, but the reinforcements are fiberglass. I'm going to have to check this one out...
04-13-2009, 03:56 PM   #18 (permalink)
blownsn95cobra
hood and deck lid are not steel mag would not stick
06-02-2009, 12:30 PM   #19 (permalink)
coolreed
1. Install a complete Maximum Motorsports Suspension with K-Member and coil overs. Use the road racing lower control arms. (about 250 lbs.)
2. Install Aluminum Heads. (about 40 lbs)
3. Rear Seat Delete. (about 20 lbs)
4. Aftermarket Fiberglass Hood (about 20 lbs)
5. Lightweight Wheels (about 20 lbs)
6. Aluminum Driveshaft (about 10 lbs)
7. Aluminum Flywheel and,..T-5 is lighter than a Tremec Heavy Duty 5 speed
8. Remove Air Conditioner (about 20 lbs)
9. Install manual steering rack (40 lbs)
coolreed is offline   Reply With Quote
10-25-2009, 10:35 PM   #20 (permalink)
cauldron
moving the battery to the back is a good way to help out with the weight that's there.
Removing all sorts of stuff helps. it's up to your imagination and how quiet and comfortable you need the car to be.
smaller brakes
Radio and speakers deleted
spare tire and jack gone
seats changed or removed
carpet and sound deadener stripped out
Then changing iron stuff for aluminum stuff.
then metal for plastic or carbon fiber
then plastic and metal for nothing...
take out the dash and all the plastic. door trim, headliner, etc.
Turn the frame into a cheese grater. Drill or punch holes in the radiator mounts, trunk supports and such. Remove the hood hinges and latch, and go to hood pins.
It's possible to strip a fox body down to 1800 pounds or so without going too crazy...
well maybe a little crazy.
cauldron is offline   Reply With Quote
gear reduction starter LXIVHg Galaxie Pages 6 01-26-2009 04:43 AM
weight reduction? any ideas how? MauriSSio Galaxie Pages 25 12-25-2007 01:19 PM
Weight Reduction BigMan Falcon Pages 6 06-29-2005 09:29 PM
Weight reduction Q drumrod All Ford Techboard 2 06-24-2005 04:54 PM
cab noise reduction dragtruckin All Ford Techboard 1 05-30-2005 04:35 AM
Probe Industries
