07-03-2009, 04:48 AM   #1 (permalink)
nikstang
Stock Intake System vs. C.I.A
I have used both and various setup as with bigger MAF and better MAF curves with custom tunes and a wide range of differnt C.A.I setup as well. I have noticed that there is actually seems to be a loss of power and torque, not to mention leaning out a various points due to the turbulence of most C.A.I. I have also been told that if the diameter is bigger than the MAF and the Thottlebody that your application is setup with you could even cause a vacuum in the air intake system, which is bad.
I am wondering if all this is true or does a 'good' CAI do what it is suppose to? What is a 'good' CAI setup?
Which filter to use with the right one?
What is the best size MAF diameter for a 70mm T/B setup?
I have an 80mm C&L that I want to use, but haven't decided how to work it in just yet, plus I need a curve to dial it in correctly and cannot seem to find one. C&L engineers weren't any help either, I think that techs are getting dumber everywhere or is it just me. They said that no matter what tube I used on this meter that I wouldn't be able to get it adjusted out, that it would always be lean... Well I know as well as the other EEC tuners out there that it doesn't matter what tube is in it or what size it is [to a certain degree] as long as you adjust the curve for it.
Any thoughts or suggestions are welcome and very appreciated.
nikstang is offline   Reply With Quote
07-09-2009, 07:00 PM   #2 (permalink)
wannamustang
Re: Stock Intake System vs. C.I.A
i think i had the same problem on my 87 that i put mass air on if you havnt got a chip yet that would help i had an e cam with gt 40 p heads and an adjustable fuel presure regulator help my car alot it seemed
wannamustang is offline   Reply With Quote
Stock fuel system enough to support 350hp? strtcar All Ford Techboard 6 09-06-2006 05:24 AM
Stock Fuel System good until? pass1over Mustang Pages (1965-1973) 4 04-05-2006 07:49 AM
cold air intake system rod123 Galaxie Pages 10 07-20-2004 04:08 PM
Limit on Stock Fuel System samferd All Ford Techboard 3 12-12-2003 09:03 PM
Air Intake System 1973 Mach1 351C 4V MonsterMach The Garage 9 02-28-2002 12:53 AM
