09-06-2009, 10:26 AM   #1 (permalink)
90notch3
carb tuning help
currently have a 306 with a proform 750 carb. i cant seem to get the tune ruight. when you smash the gas at idle it often pops through the carb. and when u are driving and press the gas 1/4 throttle or more it stumbles really bad. i currently have a cheap air/fuel gauge that says its really rich at idle and goes lean when i press the gas. i dont know how accurate these are but i currently have 71, 76 for jets.... 75 primary air bleweds 72 sec, and 36 high speed.
let me know
thanks
90notch3 is offline   Reply With Quote
10-25-2009, 08:26 PM   #2 (permalink)
cauldron
Re: carb tuning help
It sounds like the arm going to the accelerator pump is not adjusted correctly. On my carb it needs to be touching at idle, with just a tiny bit of pre-load.
If that is correct, the 750 might just be too big, and the air going through it is going too slow off idle.
But I would bet the cam and lever on the accelerator pump need adjusted tighter.
cauldron is offline   Reply With Quote
Carb tuning Yeti All Ford Techboard 4 11-16-2007 09:23 AM
Carb tuning FURACERMAN All Ford Techboard 4 08-16-2005 06:47 AM
Help on tuning carb please! 69Tyler302 All Ford Techboard 17 12-16-2004 10:25 PM
Carb tuning ckelly All Ford Techboard 4 09-01-2003 06:43 PM
CARB TUNING:All carb "Experts" leave your "Tuning" secrets here!Then we'll all be able to tune'em gtfordified All Ford Techboard 15 04-27-2002 12:26 AM
