09-09-2009, 06:17 AM   #1 (permalink)
buickbear
From 4 to 8 swap in a fox
What parts are needed to swap a 4cy fox over to a v8? Crossmember, radi?
buickbear is offline   Reply With Quote
09-09-2009, 07:43 AM   #2 (permalink)
73FordDriver
Re: From 4 to 8 swap in a fox
5.0? or 5.8?
73FordDriver is offline   Reply With Quote
09-09-2009, 08:54 AM   #3 (permalink)
buickbear
5.0 carb from 4 fuel injected
09-09-2009, 02:24 PM   #4 (permalink)
Bullitt331
The K-member is the same. Bigger radiator, front suspension, rear suspension (i.e differential and springs, shocks ect) brakes just to name a few.
Bullitt331 is offline   Reply With Quote
09-09-2009, 04:03 PM   #5 (permalink)
buickbear
how hard is it to change the brakes over? or is there a better up grade. What about crossmember?
09-10-2009, 03:50 PM   #6 (permalink)
Bullitt331
Maybe the transmission crossmember has to be changed. It may also be the same for the V-8. The K-member the engine bolts to is the same for either the 4 cyl or V-8. If you are uncertian about the trans crossmember, just use one out of a 5.0 Mustang.
09-13-2009, 09:14 AM   #7 (permalink)
Bluemr24
A 5.0 donor car would be ideal, but since you're going carburetor, you don't need all the electronics, etc. Still, the fuel tank must come down, change the pump, lines, etc., all the exhaust system, and front spindles from a 5.0 car would help braking.
Some guys choose to keep the 4 cyl. springs up front, but the 7.5 rear has to go too. Cant think of much else, but this is a lot easier than going EFI.
MikeR
Bluemr24 is offline   Reply With Quote
09-13-2009, 08:16 PM   #8 (permalink)
Forged331
EEC Performance Here is a good guide.
Changing a Fox Mustang from a Four Cylinder to a V-8 - 5.0 Mustang and Super Fords Magazine Another guide.
1979 to 1993 Ford Mustang 4 Cylinder v8 Swap Mustang Engine Swap Conversion And here you can buy a guide.
Hope this helps. My 92 is a 4cyl conversion and you would never guess. The 4 bangers are better imo because the chassis hasn't been abused...you can also build it up the way you want it as you go along.
-Steve
Forged331 is offline   Reply With Quote
10-25-2009, 08:45 PM   #9 (permalink)
cauldron
New motor-mounts
Trans cross member is the same
Bigger radiator
Trans cooler
trans cooler lines
Tach needs changed from 4 to 8 setting
front springs and struts
total exhaust system
ignition box (set MSD to 8) duraspark works
some accessories like power steering and alternator will work in either
Different pulleys on accessories
Bigger battery
new heater hoses
bigger electric fan, or flex fan, or bigger fan with fan clutch
PARTS TO MAKE A 5.0 RUN A CARB
Intake manifold
carb
lots of vacuum line
accelerator cable (and bracket on intake)
kickdown linkage
Timing indicator (sometimes it's the same)
new fuel line from tank
new front cover with port for mechanical pump
fuel pump cam
and pin
and spacer for pin
new front seal
new oil pan gasket ('cause it has to come off for the front cover)
air filter that fits under the hood when it's shut
cauldron is offline   Reply With Quote
mod swap Dave Street Rod Forum 2 12-02-2008 01:08 PM
5.0 swap Nosboss Late Model EFI Techboard 3 04-06-2005 02:03 PM
V6 to V8 swap???? clay24 All Ford Techboard 3 08-15-2003 06:33 AM
Are the granada swap just as good as an aftermarket disc swap for mid 60\'s fords chris21 All Ford Techboard 11 07-10-2003 11:32 PM
351 swap dragonmark All Ford Techboard 5 06-02-2003 05:59 PM
