10-15-2009, 02:26 PM   #1 (permalink)
347sn95
1995 gt Compression Test
I want to do a compression test on my 95 gt, but don't know what psi range i should be in. Motor has about 4k on it since rebuild. Does anyone know what the reading was when the was new?
347sn95 is offline   Reply With Quote
10-15-2009, 03:12 PM   #2 (permalink)
fordman460
Posts: n/a
Re: 1995 gt Compression Test
Lot of different things can change the max pressure you will see in your engine. So the test is done to find a cylinder or cylinders that is not as good as the others.
10-16-2009, 07:24 AM   #3 (permalink)
Bullitt331
If all of the cylinders are within 10% then no worries. I have seen 5.0's that have only 100 psi cranking and ran like there was no tomorrow. So as long as the low cylinder is within 10% of the highest cylinder, call it good.
Bullitt331 is offline   Reply With Quote
Compression Test MusclePoney All Ford Techboard 5 12-09-2007 05:50 PM
anybody done a compression test? Fordota All Ford Techboard 4 05-02-2007 06:19 PM
compression test ?? NoLongerHere2 All Ford Techboard 4 04-09-2005 11:38 PM
Compression Test....Is this too low? RonMeyer All Ford Techboard 8 09-04-2002 12:50 AM
Did a compression test. 7.5:1 - 8.3:1,,, TOO LOW? andysam All Ford Techboard 10 07-09-2002 08:29 PM
