10-19-2009, 07:44 PM   #1 (permalink)
165falcon
manifold swap problem
I just helped a buddy finish up his manifold swap went from stock to trick flow trackheat now when the rpms reach 3000 the engine starts to shut down ???????????????? the manifold is set for 75mm t/b and he has a 70mm, but the guy he got it from said it would be fine is this the problem or can it be something else please help Thanks
165falcon is offline   Reply With Quote
10-19-2009, 08:17 PM   #2 (permalink)
Re: manifold swap problem
running out of fuel??
Honor!
10-20-2009, 12:17 AM   #3 (permalink)
PSIG
Originally Posted by 165falcon View Post
...when the rpms reach 3000 the engine starts to shut down ???????????????? the manifold is set for 75mm t/b and he has a 70mm, but the guy he got it from said it would be fine is this the problem or can it be something else
Something else. Can I assume the ECU has been re-programmed to run properly with the new intake? More info would be helpful.
David
PSIG is online now   Reply With Quote
10-20-2009, 08:28 PM   #4 (permalink)
165falcon
no the guys at a performance shop here in town told him that it didnt need to be re -programed his motor is 30 over with th e303 motorsports cam it has 24 lbs injecters so i am not sure? dont know much about fuel injetion
10-21-2009, 07:45 AM   #5 (permalink)
73FordDriver
im new to fuel injection as well but im pretty sure the ecu has to be programmed to run the bigger TB
Ryan
73FordDriver is offline   Reply With Quote
10-22-2009, 08:03 AM   #6 (permalink)
Beoweolf
The MAF sensor does need to be changed, modified or replaced with appropriately cinfigured one that recognizes Injectors have been replaced with larger ones. There computer does not recognize that automatically. By default it assumes they are 19 lb's.You can change TB without modification of the computer, however - the TPS throttle position sensor, may or may not need to be monitored or adjusted. It should be a direct swap, but some people insist that you check it for correct voltage.
10-22-2009, 08:43 AM   #7 (permalink)
BobsSleeper
I would go back and retrace all the work that was done to install the intake. That in-stall should run perfect right out the box. (mine did) You might want to in-stall a adj fuel regular with a gage on the fuel line. (a must when you start modding on a EFI 5.0
89,5.0,5spd hurst,410 gear,GT40P heads-(Fox Lake) TF stage 1 cam,TF intake,65mmTB,76mass,MDS box-dist,UDP,Mac headers-exhaust,1.6 crans,fiber glass(stock hood)
BobsSleeper is offline   Reply With Quote
11-02-2009, 07:10 PM   #8 (permalink)
EUGENE477
Put a fuel pressure gauge that you can see while driving and see what happens under a load. The pressure should spike when the throttle is wide open and should hold pretty steady.
EUGENE477 is offline   Reply With Quote
Ms. American 3.14159's Exhaust Manifold Problem JCAllison Galaxie Pages 37 11-05-2008 10:00 AM
406 intake manifold number problem. 428cjmaverick Galaxie Pages 14 11-09-2006 09:54 AM
swap of efi bronco upper manifold to mustang upper manifold ? lilian Late Model EFI Techboard 3 07-26-2005 03:09 AM
Manifold gasket PROBLEM need helppppppp NoLongerHere2 All Ford Techboard 2 06-28-2004 07:05 AM
Intake Manifold Sealing Problem sinistertrucker All Ford Techboard 15 02-06-2003 11:59 PM
