10-31-2009, 06:38 PM   #1 (permalink)
5ofun
Shorting out when try to start (95 GT)
Not the battery. When insert key, all dash lights come on normal but everything dies when turn key. Get one click and then silence. If I wiggle the red cables coming off the battery that go down by the headers to the starter/tranny area starts right up on next try! Used to have an AODE in it but now T5, but using original AODE wiring, if that makes any difference. Has been running fine since the swap - til now.
Any ideas? How to locate probelem? Or just get a cable kit to replace OEM for just that segment of wirng? If so, where and part #?
Thanks in advance.
5ofun is offline   Reply With Quote
11-01-2009, 03:12 AM   #2 (permalink)
5851a
Re: Shorting out when try to start (95 GT)
Sounds like a bad connection at the starter terminal.
11-10-2009, 10:14 PM   #3 (permalink)
mikes82GT
Make sure the battery terminals are clean and ALL connections are tight.
EVERY vehicle that's come to me with those symptoms have been battery or cable related.
mikes82GT is offline   Reply With Quote
11-10-2009, 10:28 PM   #4 (permalink)
You got crappy connections there fella.... Clean ALL the grounds and positives....
Honor!
Wierd question-why ISNT my fuel sender shorting out? v8shadow All Ford Techboard 8 05-17-2008 07:22 AM
Before I start it I should.......... finkster Falcon Pages 6 11-19-2006 09:49 AM
when 460 is hot, doesn\'t want to start back up on shut-down...vapor lock/start heat soak? XolieX All Ford Techboard 29 04-25-2005 08:03 PM
Tires rubbing and shorting the rear axles. Quid All Ford Techboard 4 09-24-2003 03:07 PM
Oh well It\'s a start! Merlin The Garage 4 08-05-2003 10:16 PM
