02-06-2006, 07:05 AM   #1 (permalink)
saleens330
Auto to manual tranny but no start
I swapped out my 4.6 and 4R70W to a 5.4 and 99 cobra T-45. I have everything done except some of the connectors on the T-45, swapped out the computer for the ford racing manual computer for 96-97 mustangs. Would not putting the connectors on the tranny keep it from starting? The battery is good and the starter worked before the swap. I know the auto is made to only start in park and maybe neutral but would that still play a factor? Also the auto shifter selector had a wire that went up to the steering column, i guess it moved when you moved the selector to drive, reverse, etc, would that play a factor with the ignition to keep it from starting, now that it's not connected? Any info will help.
saleens330 is offline   Reply With Quote
02-06-2006, 06:47 PM   #2 (permalink)
fastEd
Does the car have the PATS (anti-theft system) with the key with an electronic chip? If so, you may have to have a dealer access the security system to reprogram it ... I believe the PATS goes through the EEC system.
cheers
Ed N.
fastEd is offline   Reply With Quote
02-09-2006, 07:04 AM   #3 (permalink)
saleens330
It does have the PATS. I'll call the FORD dealership and see if i need to bring it in to get reprogrammed. Thank you
02-09-2006, 07:05 AM   #4 (permalink)
saleens330
The egine swap in my 95 Mustang GT was so much easier.....
<font size=-1>[ This Message was edited by: saleens330 on 2/9/06 9:06pm ]</font>
02-09-2006, 07:16 AM   #5 (permalink)
saleens330
I called FORD and talked to one of their techs, he said there's a security module that it goes through but it shouldn't go through the computer.
02-18-2006, 07:08 PM   #6 (permalink)
1 Bad 88 GT
You must hook up the safety switch on the clutch pedal so the starter will turn over.
02-23-2006, 10:48 AM   #7 (permalink)
saleens330
It was the transmission range not completing the circuit, i by passed it all and now it runs.
