12-13-2006, 03:25 PM   #1 (permalink)
tamsj7
Engine swap, 4.6 to 5.0
Just purchased a 2002 GT and have a 347 stroker that needs a new home. The car has a 5 speed manual trans. Seems to be little or no info available about what is involved in what should be a commond swap. Anyone know where to look on the internet or have first hand experiance with this swap?
tamsj7 is offline   Reply With Quote
12-17-2006, 11:57 AM   #2 (permalink)
tamsj7
12-17-2006, 12:05 PM   #3 (permalink)
tamsj7
I am adding what little INFO I have aquired to maybe prompt some constructive input. First the K member must be swaped from a 94-95 Mustang which will provide usable engine mounts. Seems as if everything from 94-95 year cars will swap over. Some how I can't believe it is all just that simple.
Still waiting for some comment. thanks
09-29-2007, 10:54 PM   #4 (permalink)
19mach69
Re: Engine swap, 4.6 to 5.0
I think you will need a new tranny also. If I remember right the 3650 has an integral bell housing and since its a mod motor pattern it won't work.
1966 Falcon- Future 460
1969 Mustang Mach 1 4spd-351w
1970 Dodge Charger R/T 440+6 4spd-Project Car
2003 SVT Cobra-Keeping mostly stock
2005 Jeep Grand Cherokee Limited 4x4 Hemi
19mach69 is offline   Reply With Quote
10-01-2007, 11:54 AM   #5 (permalink)
bassman97
Yes, it is that easy. Just swap in a stock 94-95 k-member or get an aftermarket piece.
10-13-2007, 03:12 PM   #6 (permalink)
wildosvt01
You WILL need a different transmission. And like the rest said a 94-95 K-member. Also a H or X pipe for a 94-95.
Wildo
1965 Galaxie Fastback-351C 2v/C4 with a 3.50 Trac-Loc
2007 Torch Red Shelby GT500
2004 Marauder/2004 Cobra
[b]Out of a job yet? Keep buying foreign!![/b]
11-08-2007, 04:25 PM   #7 (permalink)
Chris_Curl
i don't think it is going to be as easy as that ...
carbed or efi?
efi: you will need to worry about the distributorless ignition/coil on plug thing; you'd probably be better off getting a T4M0 or J4J1 computer from a 94/95. then you'll need the harness for it ...
carbed would probably be a lot more straightforward.
if the car has a 4R70W, then a 1999+ v6 4R70W bell housing fits the 347
then there is the problem of hooking up the older computer to the newer instrument panel ...
contact the guy here: SorsCodes WebSite
Black 1967 Fairlane GTA convertible ... restoring to stock
Black 1995 Mustang convertible ... 410 stroker, AFR 205s, AOD ... a perpetual work in progress
Chris_Curl is offline   Reply With Quote
11-12-2007, 04:12 PM   #8 (permalink)
sharpshot71
i was kinda wondering the same thing, if i could pick up a v6 mustang or a v8 later model with a junk engine or trans, and swap in a pushrod sbf and 5spd, sounds like it would be fun
