cammin
You shouldn't base cam selection on this since your low-end power will suffer a ton. If you are going to keep the stock heads (not ported versions), then Comp 262AH and VT stage 1 cams are your best bet (or something similar). They will give you some of the sound you're looking for but will give you a better power/torque curve than what you actually want.
