09-01-2007, 08:04 AM   #1 (permalink)
cdjnight
Gt Supercar Fuel Pump Install
SEE T63 IN MUSTANG POST TO SEE PICS, BUT I INSTALLED A FORD GT SUPERCAR FUEL PUMP IN MY 2003 MUSTANG GT AND IT STARTED RIGHT UP WITHOUT ANY PROBLEMS. ALSO i DIDNT DROP THE TANK ALL THE WAY OUT. I JUST REMOVED STRAPS AND BOLTS FROM FILLER NECK AND WITH THE CAR ON JACK STANDS I LOWERED THE TANK ENOUGH TO GET TO FUEL PUMP WITH PLENTY OF ROOM TO WORK.
cdjnight is offline   Reply With Quote
09-29-2007, 10:42 PM   #2 (permalink)
19mach69
Re: Gt Supercar Fuel Pump Install
I'll be doing that on my 03 Cobra also. I'm looking at getting a whipple 140AX or KB 2.6+ and joining the twin screw club. From what you say its sounds like a fairly easy job. How much was it, and where did you purchase it from?
1966 Falcon- Future 460
1969 Mustang Mach 1 4spd-351w
1970 Dodge Charger R/T 440+6 4spd-Project Car
2003 SVT Cobra-Keeping mostly stock
2005 Jeep Grand Cherokee Limited 4x4 Hemi
19mach69 is offline   Reply With Quote
10-04-2007, 01:54 PM   #3 (permalink)
Ron1
Keep in mind that the GT has 2 pumps to support the power. We have done the swap as well. Depending on your power output, make sure you measure pump duty cycle when tuning.
Ron
65 Mustang Fastback
347 CI, C4 w/TB, 4.56 gears
Best 1/4 N/A: 10.60 @ 123
Best 1/4 N2O: 9.74 @ 136.99
Best 1/8: 6.17
Best 60: 1.360
Ron1 is offline   Reply With Quote
10-04-2007, 07:17 PM   #4 (permalink)
cdjnight
Ron
I'm not positive but I will look to make sure, but I think the Sniper software allows me to program the max duty cycle of the pump. I made 475hp when the rods let go in this motor and it was know where near lean, so I would say its keeping up just fine.
Momentum is everything, until you drive off a cliff!
Factory Five GTM Supercar alanmacdougall The Garage 7 06-21-2007 11:43 AM
Where do I install my Fuel pump cut-off switch? strtcar All Ford Techboard 3 02-10-2007 04:47 PM
electric fuel pump vs. manual fuel pump JoeD All Ford Techboard 13 06-30-2005 07:23 PM
Mechanical fuel pump VS. Electric fuel Pump growlin351w All Ford Techboard 16 08-01-2003 09:28 PM
Re: GT supercar article coupe3w The Garage 7 11-29-2002 11:00 PM
