09-18-2007, 08:11 PM   #1 (permalink)
cdjnight
boosted oil leak on crank bolt??????
anyone have problem with dampner leaking on a boosted 4.6, I changed it before I put the turbo on and added a little silicone like instructions said but now it leaking from the bolt, could it because I didnt use high temp siicone or not enough or just because of the turbo putting boost into the pvc valve? Any help or suggestions would be great!
Momentum is everything, until you drive off a cliff!
cdjnight is offline   Reply With Quote
09-18-2007, 08:12 PM   #2 (permalink)
Re: boosted oil leak on crank bolt??????
You mean the harmonic balancer? That dampner?
09-19-2007, 07:17 PM   #3 (permalink)
cdjnight
yes, lol it was late and I can't type...
09-19-2007, 07:45 PM   #4 (permalink)
MontegoMan351
I'd suggest getting Ford RTV...the 7.3L assembly silicone...it comes in a short caulking gun tube, so it's super easy to use. It is some tough stuff, we use it for practically everything at work. It's like $15 or so a tube...but well worth it!!!
'73 Montego MX 357C Homebuilt EFI, 9.5:1 comp, mild cam, 30lb injectors, A9L computer, Moates.net chip, 70mm TB, 76mm C&L mass air.
MontegoMan351 is offline   Reply With Quote
09-22-2007, 12:06 PM   #5 (permalink)
cdjnight
Oil leak is taken care of till my new bottom end shows up, It broke a rod, 475hp 5000 rpm top of third gear with 8 lbs of boost, 11.8 a/f ratio and it sprung a big leak in the side of the block, second one back on driver side broke the rod about 2 inches below the rist pin. Rod bolts held up though, it was still fling the bottom half of the rod around the crank case when I shut it off.
09-26-2007, 11:02 PM   #6 (permalink)
ford4v429
ouch- sorry to hear...a guy at church has a K-B 8# on his 05, runs 12.5's, I want one bad, but the PM rods do scare me- have heard about 450 the PM rods are getting a bit marginal...I might just consider 6# K-B and 5k rev limiter- I'd just love more bottom end torque for everyday driving- thats about the ONLY thing the 06 is lacking to me
Confidence: that feeling you have just before you realize the mess you've gotten yourself into...
http://www.hometown.aol.com/ford4v429/gal1.html
ford4v429 is offline   Reply With Quote
10-04-2007, 08:30 PM   #7 (permalink)
cdjnight
Took all my parts to engine builder, he said there was no sign of detonation or leaning out, it appeared to him that the stock piston failed from the preasure. Then the rod flew around and destroyed itself and the block. The preasure could have been the result of too mcuh timing and/or boost. Reguardless this guy has been building and racing motors for 30 years and was positive the piston failed first. I think if it was feasable a guy could put forged pistons on the factory rods and make 475-500hp all day long. But thats hard to justify not replacing the rods while the motor is apart.
Help!! 1997 4.6L (8 bolt crank vs 6 bolt crank) nu2fords Truck Forum 0 03-18-2007 01:48 AM
eagle crank- 2 piece seal = leak! hotrodconsolo All Ford Techboard 2 11-25-2006 05:36 PM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Mustang Pages (1965-1973) 6 10-31-2006 08:00 PM
What year did Ford switch from 3 bolt to 4 bolt crank balancers? Frank Truck Forum 2 10-27-2006 10:12 AM
That Big Bolt in the end of the Crank....?? ZRX61 All Ford Techboard 4 10-18-2002 12:13 AM
