10-26-2007, 11:36 AM   #1 (permalink)
dataylor
Engine swap; 4.6 to 5.4
Does anyone have any experience and or knowledge reference the engine swap procedures for a 2002 GT 5 speed with the 4.6L engine to a 5.4L engine.
My Gt has 58,000 miles, runs well and has minor modifications that include a Diablo program and a MAC Cold Air Induction system; all of which work quite well.
Thanks for your input.
dataylor is offline   Reply With Quote
10-26-2007, 12:05 PM   #2 (permalink)
boss302isback
Re: Engine swap; 4.6 to 5.4
i've seen alot of info on this swap on modularfords.com
Rather Be Blown
"Remember...Ford does things exactly a certain way....except sometimes!"
Cheap, Fast, and Good...you can only have two :'(
boss302isback is offline   Reply With Quote
10-26-2007, 02:13 PM   #3 (permalink)
bassman97
Here's the bible: Anyone intrested in 5.4L swaps, in here. Need you to opine. - Mustang Forums
It pretty much straight forward and the only parts that need modifying are the mid-pipe (lengthening/widening) and adaptor plates for the intake (though soon, HPS will have a specfic 5.4 intake).
10-29-2007, 04:48 PM   #4 (permalink)
76grantorino
[quote=76grantorino;1366557]Thanks i almost had all the mods picked out for my stang until i saw this thread. What is the weight diff and the horsepower diff of the two engines.And of course is the MPG diff. Can the trans hold the power of a 5.4 slightly modified or maybe the Lightning2V.
76grantorino is offline   Reply With Quote
10-29-2007, 07:13 PM   #5 (permalink)
bassman97
The weight diff is around 30 lbs, which is offset by any aftermarket k-member. Staying 2V, horsepower will be similar (obviuously 5.4 will have more but not too much more) but the torque is sickening. Mileage wise, I'm assuming city is a tad worse but from what I hear, highway is similar. As far as the trans, the stock T45/TR3650 will hold up fine, if you drive like a granny. As for the Lightning engine, don't expect the blower to fit under the hood but if you use the shortblock, beef it up w/ forged internals. Check out the link I posted since any question you will ever have is probably answer there.
11-02-2007, 05:47 PM   #6 (permalink)
dataylor
Thanks for the information. You were correct, that web page/sight has excellent information on the subject !!!
Thanks again and Stay Safe.
11-19-2007, 10:21 PM   #7 (permalink)
cdjnight
I'm doing the swap and have used that website alot for the swap. Its been a great help! I just decided to make it more difficult and keep the turbo.
Momentum is everything, until you drive off a cliff!
cdjnight is offline   Reply With Quote
10-21-2009, 06:27 AM   #8 (permalink)
jumpstart
Thumbs up Re: Engine swap; 4.6 to 5.4
I am going to put a 5.4L 605HP crate motor in my 96 Cobra. I know the headers will not work and I am hoping that someone knows who makes long tubes. Thats the only thing holding me up.
I have a spec stage3 clutch, TKO500 trans, and a strang 9" 410 rear end.
Some say the hood will hit. The crate motor has a supercharger so I should be a little lower.
The reason I am changing? My motor blows oil after 5,000RPM (BLOW BY).With the blow by she only puts out 270HP, but still runs a 13.26.
jumpstart is offline   Reply With Quote
10-22-2009, 12:56 PM   #9 (permalink)
bassman97
FTP is making 2V sets. I can't imagine 4V versions being too much more of a change.
67 engine swap swatt20 Truck Forum 3 08-05-2007 04:47 PM
Engine Swap hokejl Late Model EFI Techboard 0 08-22-2006 09:16 AM
289-351 engine swap Easy1 Mustang Pages (1965-1973) 10 11-24-2005 06:35 PM
352 - 390 Engine swap lgh1157 Galaxie Pages 15 07-30-2005 11:24 AM
96 f-150 engine swap daves87gn All Ford Techboard 0 02-05-2003 11:49 PM
