12-31-2007, 01:29 AM   #1 (permalink)
76grantorino
TRANS. and DRIVELINE
looking to get a new shifter Where do i find out on the trans which one i have ????? Also which aluminum driveline is the lightest(stok is 39.1lbs) and can hold 400hp
76grantorino is offline   Reply With Quote
12-31-2007, 09:52 AM   #2 (permalink)
bassman97
Re: TRANS. and DRIVELINE
96-01.5 is T45, 01.5+ is TR360. If you are still in doubt since you have a 01, the door tag tells you what trans you have. If it says K under TR on the door label, it's the TR3650. Also, save your cash for the driveshaft. Al, unless the design permits less inertia over the stock piece (both mass AND SIZE determines inertia), could reduce performance and for the money, you can get other stuff for your car.
12-31-2007, 12:55 PM   #3 (permalink)
76grantorino
so to make sure i understand if the weight is reduced , the most ive found is up to 6 lbs, but the size is bigger the inertia willstaythe same?????
Almost all aluminum driveline advertise less inertia over stock please explain more for the not so mechanically-inclined Thanks for all the help
12-31-2007, 01:40 PM   #4 (permalink)
bassman97
Most companies advertise that less weight improves performance but that is only a small part. A good way to see how this works is get 2 identical rings in which one is solid and one is hollow. Put both on a ramp and see which starts to move first, which will be the solid one, despite the increased mass.
01-03-2008, 07:39 PM   #5 (permalink)
76grantorino
the trans is starting to shift roughly. from 1st to 2nd it feels like its going into gear but it will jump out. Then when i try to put it back in it grinds. also it will feel like there is a bar in front of 3rd preventing it from going into gear so il wigle it in neutral an itl go. it will also do this for reverse so ill put it in 1st then reverse and it will work.Any ideas whats wrong??? Had the trans and diff. fluid changed at 54K and its only 59K. Thinking of putting Lucas in the trans and diff.to see if it helps. also gonna try The z max fuel and oil treatment. I use royal purple 5w20 and dont know if i should mix the royal purple ,zmax oil treatment, and the lucus oil stabilizer
01-03-2008, 08:36 PM   #6 (permalink)
bassman97
If you have the TR3650, there is a TSB to replace the synchros for 2nd and 3rd and also the manual states the wrong fluid level which may have caused you to overfill the trans.
01-04-2008, 03:16 PM   #7 (permalink)
76grantorino
Do you know what the proper fill levels are supposed to be? i have an 03 gt door panel tr said K so i assume i have the TR3650. I have the upr blue thunder shifter w/ extreme stick on its way. Have you looked at the sct livewire tuners??? i think i might get this one over the predator.
01-04-2008, 04:46 PM   #8 (permalink)
bassman97
Here's the info on it. For me, I used Redline D4 ATF when I did mine.
Tremec 3650 Overview
Driveline MCCUTCHEON4 All Ford Techboard 8 05-11-2007 07:56 PM
new driveline yoke 19mach69 All Ford Techboard 2 06-05-2005 12:49 PM
stupid driveline company cut driveline too short!!! XolieX All Ford Techboard 14 01-10-2004 04:22 AM
Driveline vibration mgray All Ford Techboard 14 04-11-2003 04:42 PM
Another driveline vibration Oscar All Ford Techboard 4 08-11-2002 03:24 PM
