03-08-2008, 08:54 AM   #1 (permalink)
damtheman69
Motor Build, what ya think
Here is what i am thinking about doing to my 03 GT, please be gentle with responses.
I want to get manely forged crank and pistons, KB 2.1L SC, Patriot Heads stage 2 with XE265H comp cams w/beehive springs, msd cop, and a 90mm MAF. I know this will cost a bit of money but, hey i have some to spare finally. Thanks for the help.
B&M Short Shifter, Flowmaster American Thunder Series exhaust, C&L Plenium, BBK 75mm Throttle Body, 1.5\" drop with Steeda Sport Springs, Tokico shocks & Struts, SIMCO Ltd gauges, Steeda Adjustable Clutch Cable and Quadrant, MMS caster camber plates
damtheman69 is offline   Reply With Quote
03-08-2008, 10:20 AM   #2 (permalink)
bassman97
Re: Motor Build, what ya think
Manley doesn't make cranks so I'm assuming you mean the Cobra crank? Also, I'd go w/ blower cams instead of run of the mill generic cams from Comp (Crower has some nice cams for this). In addition, for heads, there are better heads out there from Total Engine Airflow, Fox Lake Racing, and Steen Racing. In addition, depending on the amount of boost you're going to run (and ultimately the amount of power), you may not need the larger MAF or MSD coils. To add to what you listed, h-beam rods, Cobra oil pump, and built drivetrain (stronger clutch, trans, 31 spline axles and diff) to handle the power. Also, as a suggestion, you may want to upgrade the suspension and brakes to help put the power to the ground and be able to control it as well (such as RCLA, subframes, and Cobra brakes).
03-09-2008, 07:07 PM   #3 (permalink)
damtheman69
i plan on the suspension and drivetrain upgrades also, just starting out with the motor first. thanks though.
03-17-2008, 01:03 PM   #4 (permalink)
87stang
Sounds like a good plan.
Have you considered a turbo (Hellion)?
Dave
\'87 5.0 LX Hatch, 5-speed
Cobra brakes
CHP 347
Help me pick my new motor build (please) Fordota All Ford Techboard 40 06-27-2007 10:32 PM
help me build a motor... 351stanger Stroker Engines 10 12-08-2005 10:33 PM
5.0 motor build VonMoldy All Ford Techboard 3 10-26-2005 02:32 PM
should i build or buy a motor 63var All Ford Techboard 8 09-08-2005 11:47 AM
302 motor build 66stang66 All Ford Techboard 2 06-17-2002 02:54 PM
