03-27-2008, 04:27 PM   #1 (permalink)
429scj429
Odometer not working
I took my stock Mystic Cobra to the shop for a tune up. Ended up replacing fuel injecter and replacing wires. As far as I know the odometer and trip meter were both working before going to shop. When I got the car back the speedometer works fine, but no movement on trip meter or odometer. Are these controlled electronicly? Could this just be a coinsidence. The guy that did the work is very repatable. Any advise is appreciated. Thanks larry
larry
429scj429 is offline   Reply With Quote
03-27-2008, 04:32 PM   #2 (permalink)
gbic1
Re: Odometer not working
Sounds like your speedo just died. They are inter connected.
]1964 Galaxie 500 fastback 352 Auto.
03-27-2008, 04:39 PM   #3 (permalink)
429scj429
What I don't understand is that the speedometer works fine. The odometer is on the speedometer side while the trip meter is on the tach side of the cluster. Are they mechanically connected behind the speedometer head?
larry
03-27-2008, 08:06 PM   #4 (permalink)
bassman97
Not sure what years started w/ the electronic units but if the odometer has a digital display, its electronic. Over time, they go so it may have just been a coincidence that it went only now. However, your speedo may work but is it still accurate? Could be a problem ranging from the speed sensor to the circuit board.
03-28-2008, 12:36 AM   #5 (permalink)
429scj429
Speedometer feels like it is right. The odo and trip meters are not digital displays?
larry
03-28-2008, 07:08 AM   #6 (permalink)
bassman97
Then you have the old mechanical speedo/odometer. Could be the gears used for the odometer may have broke (since it's all plastic in there).
03-28-2008, 03:40 PM   #7 (permalink)
429scj429
Thanks everybody. I found a factory service bulliten for 96 mustangs. The odometer gears where prone to breakage. Especially if car has periods of non use.
larry
working under car Ralphw All Ford Techboard 12 01-08-2008 05:14 AM
Seems to be working right now black93lx C4 Transmissions 0 01-04-2007 09:13 AM
Speedo jumping and odometer not working Beoweolf Galaxie Pages 6 06-21-2005 08:03 PM
94 gt odometer problems rcodenewf Late Model EFI Techboard 0 06-01-2005 10:31 PM
sig not working jay50 The Garage 1 04-16-2004 10:56 PM
