04-24-2008, 07:05 PM   #1 (permalink)
Stangboy69
Starting Issue !?!
Hey everyone. My '96 has sat for awhile with a dead battery. Yesterday I bought a new battery and put it in. Car starts right up, runs for about a second and then dies. Fuel pump sounds fine. What gives??
Stangboy69 is offline   Reply With Quote
04-24-2008, 08:12 PM   #2 (permalink)
Re: Starting Issue !?!
Fuel pump is done....
How long is this second that you are talking about?
It's likely that your fuel pump has enough to charge the rail for a jiffy then not enough to supply the injectors while running...
Put a tester on your fuel rail...
FE
04-24-2008, 09:50 PM   #3 (permalink)
mustang42782
My dad had the same issue. Would run for a min or two then die. Changed fuel pump and all is well now
05-01-2008, 10:08 PM   #4 (permalink)
Stangboy69
It literally runs for a one-mississippi and then dies. And it doesn't stumble and die like if it were starving out and running lean it just shuts off. It acts as if I were simply turning the key back to off. I got into it and tore out the whole alarm system that it had, thinking that that would eliminate the possibility that the alarm system was killing it, but no luck. . .
not starting when hot jrod Torino Pages 10 05-02-2008 08:18 AM
Help me with my starting issue please PaulG Galaxie Pages 27 03-20-2008 09:23 AM
starting SweetStang All Ford Techboard 12 01-18-2007 08:24 AM
Car starting by itself....How and why? kywookie All Ford Techboard 6 04-13-2004 05:46 PM
Starting when hot Cheesycook All Ford Techboard 7 06-06-2002 09:38 AM
Holley
