04-07-2009, 02:05 PM   #1 (permalink)
cbowers6774
Heads and Cams
Hey I was just curious if anyone had any good sugestions on what the best heads and cams setup on a 2002 gt would be. The input would be much appreciated.
cbowers6774 is offline   Reply With Quote
04-07-2009, 09:10 PM   #2 (permalink)
bassman97
Re: Heads and Cams
It all depends on application. A stage 1 port job for heads is fine for most cases but higher rpms, FI, etc. will change that. Same goes for cams. However, Trick Flow is coming out w/ their 2V heads soon (I believe this month) so I'd wait to see if those are better for you. Again, it all depends on what your goals are.
05-10-2009, 04:34 PM   #3 (permalink)
jwyche
Re: Heads and Cams
I can tell you about one combo that's going together. Recently I ordered a 5.0 stroker built on a Teksid aluminum block. The heads that are coming are Patriot Stage 2 with Cushman (VT) Stage 2.5 cams. I'm using the Victor Junior intake with Dragon plenum and 75 mm TB. It's all going into my 2002 GT that I bought new.
I'm over 60 years-old and am calling this car "The Last Hot Rod". I have high hopes for it with a 150 shot of juice.
BTW, Jim Cushman at Cushmanmotorsports.com will talk to you about your set up and is a great guy.
Jim W.
2002 Mustang GT, Mineral Grey, auto,3200 stall, CAI, Steeda Underdrive, Teksid 4.6/5.1 Stroker, Patriot Stage 2 Heads, Cushman Stage 2.5 N/A , Edelbrock Victor Jr,
Basic Senior Citizen Daily Transportation]
jwyche is offline   Reply With Quote
06-14-2009, 12:42 PM   #4 (permalink)
2kslvrgt
Re: Heads and Cams
i did patriot stg2 heads with a .55 lift cam from comp. :-/ iam not as happy as i thought i was going to be
2kslvrgt is offline   Reply With Quote
10-10-2009, 12:15 AM   #5 (permalink)
Cobra GT
Re: Heads and Cams
I would go with the new Trickflow head that just came out if you want to spend that kind of money. They flow much better out the box than the stage II and III ported heads. I have a few items that you might be interested in when you decide which heads you are going to go with. I was headed in the same direction as you before I sold my GT and bought a Cobra. See link below and hit me back if you are interested, good luck.
http://www.fordmuscle.com/forums/eng...parts-nib.html
1996 GT (sold)
1997 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
cams help jerin5.0 Mustang Pages (1979-1995) 28 12-08-2008 11:14 AM
Anyone running Comp Cams Magnum HR cams? pbrown All Ford Techboard 4 11-10-2005 06:43 PM
CAMS, CAMS, CAMS AHHHHHH 1991CHP Late Model EFI Techboard 9 01-25-2005 06:08 PM
Old cams were a lot different than modern cams blkfrd All Ford Techboard 5 11-18-2003 10:41 PM
Cams 67stang All Ford Techboard 4 01-11-2002 10:34 AM
