08-17-2009, 09:48 AM   #1 (permalink)
65falkone
what is the stock spring rate for a 98 gt?
I have a set of stock 98 mustang Gt front springs that I want to use in a custom application. I just need to know what the stock # rating is.
Pierre
65falkone is offline   Reply With Quote
08-18-2009, 06:25 PM   #2 (permalink)
bassman97
Re: what is the stock spring rate for a 98 gt?
I want to say it should be around 460 lb/in.
08-19-2009, 07:42 AM   #3 (permalink)
65falkone
Thanks - I want to cut a coil off and use them on my Mustang II front end in my 390 FE 65 falcon. They fit perfectly diameter wise but are just a little long. hard to find that # info online but looks like you are about right. The stock V8 M2 springs are around 350 lbs which apparently is a little soggy for an FE car.
Pierre
08-19-2009, 08:12 AM   #4 (permalink)
bassman97
If you need something stiffer and shorter, Mach 1 springs are 650 lb/in and are a 3/4" drop on SN95 cars. Not sure if that's too stiff/short but those springs are fairly easy to find.
Cam & Valve spring rate question biglaw22 All Ford Techboard 4 10-30-2007 08:30 AM
64 galaxie spring rate ? GalaxieJoe67 Galaxie Pages 1 12-08-2006 03:05 PM
spring rate 3154tm Falcon Pages 1 10-09-2006 02:36 PM
42-437 rear leaf spring rate? jeffstar All Ford Techboard 0 03-21-2006 11:53 PM
Spring rate, Struts and shocks, what brand for 93 5.0? mustangdynoman Mustang Pages (1979-1995) 0 01-14-2006 01:11 AM
