10-13-2006, 08:20 PM   #1 (permalink)
ixtlan
S-197 Tank Fill fix
Fixed my fuel tank fill problem that popped up recently.
I included detailed instructs with pics and believe I found the problem.
Works great now!!!!
Go to the tech pages at http://ratstangrestoration.com/.
10-26-2006, 01:14 PM   #2 (permalink)
metroplex
S-197 Tank Fill fix
Hey, thanks for the info.
My 2003 E-250 had a similar problem where removing the gas cap would cause a hissing sound, and P1450 DTC was set in the PCM.
I found a spider egg sac that clogged the fresh air intake hose upstream of the filter assembly. There was no dust/dirt in the filter assembly.
I believe the majority of Fords with the evap canister assembly mounted in that location has the same problem with dust/dirt/acorns clogging up the filter and air intake hose, but that won't cause a slow to fill condition. I hope you did fix the problem, because you can always stuff metal mesh or a nylon mesh right at the fresh air intake area to prevent large objects from clogging up the filter.
metroplex is offline   Reply With Quote
10-27-2006, 02:48 PM   #3 (permalink)
ford4v429
S-197 Tank Fill fix
I hope it keeps working for you- sorry but I dont think this is the only culprit only because mine refused to fill the initial 2 fillups- actually puked gas all over the place after the nozzle clicked off at full- obviously vent issue, but that filter would not be clogged when new...
the problem seems to appear more often during cold weather- less vapor when colder, so that seems odd to me...anyway, if mine does it again this winter, I'm gonna try something: a piece of 1/4 OD fuelproof (nylon?) tubing, heated/bent with a 180 hook on one end, cut to length needed just to protrude into tank, push in/hook at filler restrictor. I think allowing a 'open path' back to the top of the fill tube will allow enough vapor out of at least that side of the saddlebag tank to at least help dramatically- if not prevent the vapor buildup all together.
thanks for the pics of that canister- I was tempted to drop mine just to see what the hell it was- it appears to be the ONLY connection between tank halves- wonder if its supposed to transfer fuel from one side to the other???but it cant do by gravity as all lines are uphill...still cant see how fuel pump on one side sucks from the other side...
hope that did fix your problem!
ford4v429 is offline   Reply With Quote
10-27-2006, 03:15 PM   #4 (permalink)
ixtlan
S-197 Tank Fill fix
Time will tell for sure.
I cant see how anything else would have done it though.
I really didn't mess with anything besides the filter.
3 tanks and A-Ok so far.
